Results 1 to 16 of 16
Thread: trying to plan a combo
    Farmington WV
    4,672
    #1
    i was thinking GT40 heads and intakes with an F cam.
    this is for budget and decent power...still blower or nitrous freindly.
    #2
    cobra intakes/ ???? heads, with an F cam
    #3
    what i need to run an X cam or similar?
    my plans are to gather all my parts (performance and body) for 12-18 months...then park the car for a few months for a complete makeover. :D mainly cause i have no garage and wont have my own for about 2 years. :(
    work
    4,057
    Hey Jared, is your pm box full again?
    Farmington WV
    4,672
    not anymore. :)
    i say best way to get your power would be trickflow stage 2 cam, trackheat intake, and twisted wedge heads, and a wet shot of spray. just my .02
    Farmington WV
    4,672
    yea i had someone else recomend saving for the TF heads. not sure on the stage 2 cam....never looked at it.
    im thinking about leaning to the cobra, edelbrock, or typhoon intake...as their new cost is a little more than id pay for used explorer intakes.
    Banned George C's Avatar
    1,490
    with the P heads or just regular 40s. if my old research was right they dont like over .500 lift all that much unless they are ported
    Farmington WV
    4,672
    so with the F cam the GT heads wont be good without port?
    Brand:Ford Racing Performance PartsProduct Line:Ford Racing CamshaftsPart Type:CamshaftsCam Style:Hydraulic roller tappetBasic Operating RPM Range:RPMIntake Duration at 050 inch Lift:226Exhaust Duration at 050 inch Lift:226Duration at 050 inch Lift:226 int./226 exh.Advertised Intake Duration:288Advertised Exhaust Duration:288Advertised Duration:288 int./288 exh.Intake Valve Lift with Factory Rocker Arm Ratio:0.512 in.Exhaust Valve Lift with Factory Rocker Arm Ratio:0.512 in.Valve Lift with Factory Rocker Arm Ratio:0.512 int./0.512 exh. lift
    Dec 2006
    Brighton Il
    11
    Check out anderson fords new top end kit. It made 32x somthing to the tire with the stock pistons.
    Solid axle ported eaton cobra
    10.94@125 1.60 60' sold
    Senior Member Shaggy's Avatar
    space
    278
    Steeda #18 cam
    Lou may have one for cheaper ?!?!?
    http://www.performanceautosport.com/...uctid=063-0018
    This cam pulled very hard with just stock heads and 3.08's cobra Intake normal bolt ons with mine.
    Do you like phill collins, u1arunit ?
    Jared, what are your goals for this new combo? What is the budget? Will this be your daily driver? How much gear are you willing to put in it?
    Knowing these answers first will help us suggest a proper combo for you.
    Farmington WV
    4,672
    1. id like ~400hp in the end (power adder obviously)
    2. budget isnt a HUGE concern as ill be buying parts for over a year...(i dont like to think about final cost. keep the wife happy)
    3. it will be a street/strip car which will be a DD for a little while after completed.
    4. i have 3.73, but planned on 4.10 with 3k stall.
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    I've always heard good things about the Holley Systemax II kit.
    Paul isn't that what your dad ran? (or at least part of the kit I believe)
    He ran 11's right?
    Farmington WV
    4,672
    He ran 11's right?
    i priced those kits.....and the trick flow kits. trick flow was about 3-5 hundred cheaper.
    i actually considered last night just buying me a decent little cam to throw into my current motor....then save up for a complete top end kit like the trick flow or something...instead of piecing together parts. at least the kit comes with all bolts and gaskets as well.
    Thats what i would do, if you just looking for something to mess around with on the street at this point and take to the track once in a while i saw get a mild street cam and some gears. I dont know what you have done to your car or any details about it, but i would say a mild cam, gears and a wet kit and you should be set until you get your money together for the top end. There are alot of cheap upgrades that do alot such as underdrive pulleys, taken off weight and stuff like that. dont know if it helped of not, but good luck.
    just saw that you said you have 3.73s already, if you got gears already throw a 2500~3000 stall in it and some drag radials for track
    Quote Originally Posted by Shaggy View Post
    Steeda #18 cam
    That is the cam I have with my Trick Flow heads and intake. Its cool for now!
  1. Replies: 11
    Last Post: 06-27-2011, 11:20 PM
  2. The real Obama plan
    By Twin01cobra in forum The Bar
    Last Post: 11-02-2008, 03:19 PM
  3. My Plan.
    By Mr. Rob in forum The Bar
    Last Post: 07-26-2007, 09:45 PM
  4. Small problem with the plan
    By DRRummel in forum Pictures & Videos
    Last Post: 03-03-2007, 09:19 AM
  5. this girl's plan blows up
    By J-rod in forum The Bar
    Last Post: 02-16-2007, 01:11 PM
