I found the problem. I haven't fixed it, but I edited this picture to show where the anti-freeze is coming from (in green) Red shows the general area where the hole is. I will be replacing both hoses, just to be sure. Hopefully this is the ONLY leak
the hose will come off real easy if you slice it with a razor plate first, it will make the hose almost slide off.
RUSH2112,
Glad you found it and it is a simple fix.
RaceFan,
Nice tip, thanks.
