Results 1 to 11 of 11
Thread: Fuel lines
    Senior Member lib88stang's Avatar
    LowHill
    2,679
    Fuel lines
    What should I use for fuel lines from the fuel rail to the metal lines on driver side by the k member? Will high pres hose with clamps hold?
    73 2.3 Turbo Pinto map351's Avatar
    Leechburgistain Mainland,Cuba
    1,534
    Arrow
    Better off with steel or AN steel braid hose. You can get 3/8 coated steel at the local parts store. I ran 3/8 Aluminum in a plastic liner to #6 AN from the pump to the fuel block on the pinto..
    I have the line tucked up close to the frame connector/floor corner it's safe there..
    289 slabside cobra
    6S1941
    40 Ford Sedan Delivery < For Sale
    Also, the 87/88 TC have plastic lines running in that location with the garter style conections both ends. They might be donor. Its been so long, I'm used to the duckbill stuff now, and forget how those hook-up, but I'm sure they come off the frame there, and have whips to the rail.
    Bob Myers
    LowHill
    2,679
    The mustang has the rubber hose with chrome fittings you have to use those special tools on and the TC motor had the lines cut but they where the hard plastic that took the clip like whats on fuel pump lines.
    Sexy and i know it fast4ord's Avatar
    Gibsonia
    772
    Mines just got clear fuel line with hose clamps, been fine for me so far.
    My collection:
    01 cobra in pieces
    02 dodge cummins
    LowHill
    2,679
    Quote Originally Posted by fast4ord View Post
    Are they rubber or plastic and do you know where to get them?
    Thanks
    Quote Originally Posted by lib88stang View Post
    What year TC? Like I said, the early TC's (86 and before) should have the duckbill clips (like on a fuel filter) and the 87/88 cars should have the garter springs (chrome fittings, need the X tool or the plastic clips to remove). I'm almost certain uoiu can get the donors from a 88 TC for this. My Capri is real goofey, it has the duckbills, but it all comes up on the passenger side, and crosses over the firewall. You guys have an 88 car down there you can look at to confirm? Is say 88 because there were running changes on the 87's that make dome of this goofey too.
    Bob Myers
    1,534
    I have the Merkur parts car here...
    289 slabside cobra
    6S1941
    LowHill
    2,679
    my motor is 86 and had the duck bills but the lines where cut at the junkyard, the mustang has the chrome ones and the 88TC I got down here has the same as the mustang.
    The simplest solution might be to swap to a 87/88 fuel rail (with garter springs) and use the 88 TC lines if you can come up with all the donor parts.
    The other options guys are saying will work too, pick your poison.
    Bob Myers
    Gibsonia
    772
    Thanks
    I'll look at my car tommorow and get back to you.
    My collection:
    01 cobra in pieces
    02 dodge cummins
  1. Fox rear fuel lines
    By Dan B. in forum Fox-SN95
    Last Post: 02-09-2012, 08:59 AM
  2. fox fuel lines
    By 92306gt in forum Ford Parts
    Last Post: 04-21-2011, 07:45 AM
  3. wtb 89-93 4cyl fuel lines
    By loutheplumbr in forum Ford Parts
    Last Post: 12-29-2010, 06:18 PM
  4. Fuel lines
    By RAYZ02GT&93LX in forum Ford Vehicles
    Last Post: 01-19-2009, 06:02 PM
  5. Looking For An 87-93 Mustang Fuel Pump And Lines
    By tjvantana in forum Ford Parts
    Last Post: 09-08-2008, 03:11 PM
