Results 1 to 9 of 9
Thread: 03 cobra suspension noise
    Aug 2009
    109
    Anyone have a noisy rear suspension on their cobra? The fix?
    03' Cobra
    Somerset Co.
    2,907
    No. The fix is a Full tilt Boogie bushing kit.
    http://www.fulltiltboogieracing.com/
    Can you describe the noise? Is it when you are on and off the accelerator pedal? Is it when you hit bumps or when turning?
    2011 Mustang GT Kona blue
    2002 F-150 FX4 true blue, with Lightning blower swap
    2004 F-150 FX4 forged bottom end, built trans, Street Lethal Performance 76mm turbo kit, Black, Gray Leather, 6"susp, 3"body on 37's
    Let us know your parts needs we will work to beat any price!
    (724)964-8419
    9am-5pm M-F
    In house chassis dyno
    Brookline
    2,897
    Mine has the IRS clunk a little bit if I don't ease into the clutch on gear shifts, but that's about all I ever notice.
    Probably the bolts on the front of the subframe they used smaller bolts to make them easier to install at factory they are smaller thanthe hole in the car
    Mt Pleasant, PA
    4,905
    Good suggestion. Get the larger mm bolts and install them.
    Aug 2009
    109
    Its anytime the suspension lowers or rises. Thanks guys, I'll give that a try.
    03' Cobra
    Mt Pleasant
    2,916
    worn bushings?? how many miles?
    +1 to the larger subframe front bolts. Definately worth trying before fronting the $$ for the full tilt kit. Not knocking the full tilt kit though... solid fix, just a little costly
    Looking for another 03/04. PM me if you have one for sale!
    Gone but not forgotten:
    '99 Cobra vert- 2846 out of 4055 born on 6.2.1999
    318rwhp/321rwtq
    '04 Ported Whipple Cobra - 3155 out of 3768 born on 3.9.2004
    583rwhp/504rwtq
  1. Squeaking Noise - T5
    By 94Cobra in forum Fox-SN95
    Last Post: 11-06-2014, 07:37 PM
  2. Replies: 125
    Last Post: 09-23-2012, 11:11 AM
  3. 96 noise
    By cwh19 in forum SN95-New Edge
    Last Post: 09-16-2009, 04:58 PM
  4. headers for 03 cobra and suspension mods
    By regan in forum Ford Parts
    Last Post: 04-03-2008, 09:04 PM
  5. Grinding noise?
    By turbostang3.8L in forum General Tech
    Last Post: 07-21-2007, 04:12 AM
