Results 1 to 3 of 3
Thread: Fuel pump shut-off switch - help
    Senior Member roush08's Avatar
    Jul 2010
    North Huntingdon, PA
    438
    I have an '87 5.0 that when I turn the key to the on position - I can not hear the fuel pump come on so the car will not start. I reset the fuel pump shut-off switch in the hatch area. Is there a fuse for the pump ? I could not see it listed in the owner's manual. When resetting the shut-off switch - should I hear a click or anything to know that it's been reset ? Mine just seems to depress and then pop right back to the position it was prior to being pushed. Any suggestions ?
    Jul 2010
    438
    Sorry - figured it out. I had the seats out and didn't realize one of the plug-ins under the seat was for a relay for the pump.
    Yep - was just going to tell you the relay for the pump is under the driver's seat - good catch!
  1. boost a pump and cobra fuel hat with pump .
    By ocrowner in forum Ford Vehicles
    Last Post: 07-16-2014, 09:17 PM
  2. Top Fuel Dragster Fuel Pump Demo single cylinder
    By speedracer in forum Pictures & Videos
    Last Post: 08-27-2011, 01:54 PM
  3. Fuel tank & 255lph fuel pump Pics inside
    Last Post: 07-18-2009, 12:14 PM
  4. Stock Fuel Shut Off
    Last Post: 10-23-2006, 12:15 AM
