Results 1 to 9 of 9
Thread: Help Me Pleasee!!!
    Dec 2006
    Melcroft
    420
    Unhappy Help Me Pleasee!!!
    My mustang has a problem and i dont know what to do! Yesterday I took it out for a quick trip to Mt. Pleasant. I was almost there when I started smelling gas HORRIBLY. I stopped and poped the hood. the smell of gas around the engine was overwhelming:( But here is the crazy part I could NOT see gas leaking from anywhere, not on the motor or on the ground. I decided i should go home. the trip home sucked it smelled like someone spilled a 5 gallon gas can in the cab, the smell was coming through the vents. when i got it home i put it in the garage and poped the hood. I shut off the engine and once again the gas smell was terrible, i turned the key back on and noticed the fuel pump sounded rather loud. i loosend the gas cap and there seemd to be alot of pressure in the tank, i do not remember the cap hissing at all before. the cap doesn't hiss on any other car i have when i remove the cap. and another crazy thing, the car ran perfectly fine. Rodeheaver's or anyone else out there that can help me figure out whats wrong pleaseee help
    Thanks
    2008 Ford Fusion SEL V6
    LowHill
    2,679
    Check your injectors, one may be leaking and it would be hard to see.
    Banned
    329
    It only take a small fuel leak to make a big smell. That small of a leak might not affect performance but aint safe. Fuel tends to evaporate very quickly when is drips on hot parts. Try to get it to do it cold. That will help you track it down. just keep cycling the key with out starting it. Check everywhere. Most common to be at a seal, or if you have a hard line rubbing anywhere. Do you have sub frame connectors on the car?
    Member itow's Avatar
    Warfordsburg/Breezewood, PA
    107
    Is it missing also? If an injector sticks open it will dump raw fuel and will smell like gas BAD.. But it would be missing as well.
    Dec 2006
    Melcroft
    420
    no it dont miss it runs fine, and yes i just had subframe connectors installed
    Mt Pleasant, PA
    4,905
    Sounds like a vent problem, maybe your gas cap vent is cloged.
    Dec 2006
    Melcroft
    420
    I took the car for a drive today and it was fine....go figure..i still think something is wrong though i'm just going t odrive it and see.
    shaler,pa
    1,010
    out in the woods
    4,948
    gotta love mustangs... is your fuel pump still loud? could be goin bad..
