Results 1 to 12 of 12
Thread: Fox rear fuel lines
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Fox rear fuel lines
    Got back to working on my fox t-bird. Dropped the gas tank last night to inspect the rear floor pans, check the tank condition and generally nose around. Turns out the metal fuel lines that run from the fuel filter (just ahead of the right rear tires) and back to the tank are in pretty rough shape...badly rusted and broke the end off of one while removing the nylon line. I'd like to replace these lines with direct fit pieces to keep it relatively stock and to just make it easier...but I can't find these lines anywhere for a T-bird.
    I was wondering if the fox Mustang lines run in the same orientation as the T-bird and if they may work as a replacement if available....the mustangs do have a much larger aftermarket than the 'birds but many parts cross over. From the tank, the lines have nylon sections that go up to the hard lines above the rear axle then run together to the fuel filter. One line has a molded nylon end that goes to the filter while the other has a push fit nylon line that goes forward under the car.
    Sound familiar??
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    Sep 2007
    Dayton PA
    3,795
    I can tell you my turbo coupe is not the same as a v8 or 4 cylinder fox. I remember seeing the fuel filter was in a weird location
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    Armagh, PA
    4,331
    Weird location?? Please elaborate. Guess I should have added that my t-bird is a 5.0L (HO/T5 swap done).
    To follow up.....just looked on LRS....found them but HOLY CRAP they are pricey!! Does anyone offer these that won't cost me a nut (or both)?? Or maybe have a parts car around that would have these lines on them?
    Thanks.
    Ahh fuque
    Member badstanglx's Avatar
    altoona
    676
    just make ur own holyhell lol
    410w n/a 10.51@129 9.88@142 on 200shot
    Armagh, PA
    4,331
    I'd go braided but SOMEONE has my roll of line!!! ;)
    Ahh fuque
    Sep 2007
    Dayton PA
    3,795
    the fuel filter is like over by the passenger side torque box in my TC I think. the fuel filter in all my fox mustangs was right in front of the tank about dead center
    01 cobra: traded
    Mt Pleasant, PA
    4,905
    I have a set of fox fuel lines off and ready to go, 75.00 for the pair.
    Is there some type of oddball flare on the lines? If not, just take off the original line, buy some new tubing and use the old line as a template for bending the new line.
    That being said, if Lou's lines fit without a lot of tweaking that seems like a good deal. Time is money.
    Jan 2011
    Allison Park, Pa.
    367
    Lou, Can you change my user name? My current one is Vince P ciganik. Please change to
    Fast Gypsy Also, make me a senior member.I have member listed now,but when I try to add Senior to it, it does not work. Thanks Vince
    Mt Pleasant, PA
    4,905
    Quote Originally Posted by Fast Gypsy View Post
    Done.
    Armagh, PA
    4,331
    If I could replicate the end of the lines I can easily make new ones. But, it was late and I did not look closely at them so I'm not sure what style flare they have to know if I can make them. I'm used to working with braded and push loc lines so thie stock stuff is new to me.
    From some internet browsing the mustang nylon/plastic hose ends look like the t-bird ends...they slide over a flare in the line then plastic hose has a clip with two legs that slides through the hose ends to trap the metal flare from pulling out.
    Ahh fuque
    Go big or go home... gmslayer's Avatar
    Nov 2008
    Latrobe, PA
    347
    Braided fuel lines
    I have a bunch of braided steel lines for sale...
    ***Braided steel lines AN size, length and hose end styles listed. All hose brands are either Russell or Aeroquip, all fitings are Aeroquip brand. I WILL NOT SEPARATE HOSE ENDS FROM THE HOSES OR WILL I CUT HOSES TO YOUR REQUIRED LENGTHS***
    1 - AN8 - 10" with 1 straight and 1 90 degree hose end $25.00
    1 - AN8 - 15" with 2 -90 degree fittings $20.00
    1 - AN10 - 4'6" with 2 -90s $40.00
    1 - AN10 - 13' with 1- 90 fitting $65.00
    1 - AN10 - 7' with 1 straight fitting $40.00
    1 - AN6 - 14' NO hose ends $50.00
    1 - AN6 -4' with 1 - 90 degree fitting $30.00
    1 - AN6 - 15' with 2 - 90 degree fittings $60.00
    ****ALL HOSES AND HOSE ENDS FOR $250.00****
  1. fox fuel lines
    By 92306gt in forum Ford Parts
    Last Post: 04-21-2011, 07:45 AM
  2. wtb 89-93 4cyl fuel lines
    By loutheplumbr in forum Ford Parts
    Last Post: 12-29-2010, 06:18 PM
  3. Fuel lines
    By RAYZ02GT&93LX in forum Ford Vehicles
    Last Post: 01-19-2009, 06:02 PM
  4. Looking For An 87-93 Mustang Fuel Pump And Lines
    Last Post: 09-08-2008, 03:11 PM
  5. Fuel lines
    By lib88stang in forum Fox-SN95
    Last Post: 04-04-2007, 10:22 PM
