Results 1 to 3 of 3
Thread: 86 GT Charging system issues (bad grounds?)
    2,247
    Question 86 GT Charging system issues (bad grounds?)
    The issue with the car is when jumped it will run fine, and then after a little driving it will lose power then die and need to be jumped again to start.
    I took my car to Advanced Auto to have it tested to see if my alt or battery were bad (both tested fine out of the car) but when in the car, the alt only reads ~10 volts and the guy at advanced suggested maybe it was a bad ground. Now, the ground wire from the battery to a bracket on the clutch cable is badly rusted, but I'm not sure how to change it. Also, does anyone have a diagram showing other grounds that I'll need to check?
    It seems like my starter solenoid has too many wires connecting to it, I could have messed this up when replacing it. Does anyone have a pic of how many wires should be on each post? I've been searching and cannot find anything. Thanks.
    Black
    Aug 2010
    Greensburg, Pa
    390
    i dont know if this will help but if u want to look at an untouched solenoid, you can check mine out....i see your white car all the time...
    Daily: 2007 Ford Fusion SE
    2,247
    Quote Originally Posted by Erics89GT View Post
    I'd swing by but I'm up at school with no car haha could you snag a picture of it?
    Black
  1. Odd charging issue
    By cwh19 in forum Fox-SN95
    Last Post: 05-22-2013, 07:00 AM
  2. Charging problem
    By crazylou in forum General Tech
    Last Post: 07-05-2010, 07:50 PM
  3. Charging system help!
    By pRojekt02GT in forum General Tech
    Last Post: 11-15-2009, 11:29 PM
  4. Bad boys + Bad girls at prp
    By 2001GTTT in forum Meets & Events
    Last Post: 05-25-2008, 01:02 AM
  5. Charging SN95
    Last Post: 08-11-2007, 12:18 PM
