That just needs a good buffing and vacum takin to it.
http://cgi.ebay.com/ebaymotors/1994-...item1e6b41315c
Does it come with a severed leg and teeth embedded into the steering wheel?
Is that a scratch on the rim? Why cant people stay away from curbs?
1969 Camaro restomod/project
1967 camaro
2011 mustang procharged
93 reef blue notch blk/int
92 calypso notch blk/int
86 t-type
1972 chevelle project
That probably hurt a little.
2004 SVT Cobra - sold
2000 Yamaha R1
2006 Yamaha R1 - Raven
More like "Smashed Supra" not "Fast Supra"
Damn, that thing is munched.
17 Ram 1500 Big Horn Hemi
16 Comp O GT Performance Pack
WOW that's nasty.
I think the zero key got stuck on that listing.
I think I spot a tiny door ding on the driver's door.
Was nick hogan driving that think last?
Wow that thing is mangled
blown 02 GT
