Results 1 to 20 of 22
Thread: mechanical vs electrical gauges
    Farmington WV
    4,672
    ok which are preferred? i know not to use a mechanical fuel psi gauge inside the car....but other than that id there anything wrong with say oil,water,tranny mechanical gauges inside? any reason one is better than the other?
    Banned
    329
    you can say your better than the "joneses" with full electical. They may be just a tad faster reacting, but there is no problem with mechanical
    Gibsonia
    772
    I run mechanical oil psi and water temp inside the car. Mechanical are accurate.
    My collection:
    01 cobra in pieces
    02 dodge cummins
    Member itow's Avatar
    Warfordsburg/Breezewood, PA
    107
    Honestly, if you use good quality (Auto Meter, Stewart Warner) either is fine and very accurate.. I personally would go with electric mainly because of ease of installation and versatility..
    Quote Originally Posted by itow View Post
    Exactly what I was thinking
    Farmington WV
    4,672
    autometer is the only gauge id run.
    how much harder is the install on a mechanical vs an electrical?
    Belle Vernon
    1,294
    I always felt that mechanical were more accurate but electric are easier to install
    '89 Mustang GT
    '04.5 Duramax
    Jones Race Car Trailers
    www.jonesrv.com
    out in the woods
    4,948
    Farmington WV
    4,672
    how hard are we talking here? all the ones i find are mechanical.
    i have to get these as my stock oil psi gauge screws up alot now..gave me a couple scares going to rodeheaver's.
    out in the woods
    4,948
    not that hard, just gotta rout the lines so they don't touch anything, dont rub nothing, by no heat...
    Blairsville, PA
    378
    Also, doesnt NHRA have rules against some of the mechanical guages running "flammable" liquids inside the car?
    2003 Sonic Blue Cobra - AccuFab Throttle Body, JLT "sonic blue" CAI, Diablosport Predator, 2.81 Pulley, 100mm Idler Pulley, Pro 5.0 Short Shifter, Bassani Catted X-Pipe, Bassani Cat-Back Exhuast, Eibach Sport Line Springs, FR500's, Corbeau A4 Microsuede seats, Sequential Tail Lights.
    1993 Ford Lightning - Gaylords Tonneau, LFP Traction bars, Eaton Posi, Cervini's Cowl hood + Roll Pan, Art Carr Valve Body.
    1995 F-250 PSD - Daily Driver
    Farmington WV
    4,672
    so say i run all 3 electrical gauges. with my stock pos 75a alt....will it cause my alt to fail? i know the fox's charging system stock sucks. i dont know if these gauges be enough to cause a drain or not.
    Blairsville, PA
    378
    Should NOT drain. Its only a sensor and a light to run them. Very little drain.
    fairmont,WV
    1,352
    jared i would go w/ electrical b/c of the ease and plus if that line for the mech breaks or fails for any reason then you have fluid all over the inside of your car and i wouldnt worry about drain they will take maybe 1amp total power if that and if you need help putting them in give me a call i did my guages in about 1 1/2 hrs
    Farmington WV
    4,672
    pm me a number. id like to get them in before the 14th.
    i found a deal on new electrical water and oil. now just needing tranny temp...or i may go air/fuel
    out in the woods
    4,948
    air/fuel you gotta splice into your 02 sensors wires
    1,171
    you are planning on doing some engine mods right? if not id say gauges are a waste if leaving it stock.
    Farmington WV
    4,672
    Quote Originally Posted by 5k#Eaton View Post
    of course engine mods!
    BUT i need gauges right now....my stock oil psi gauge is flaking out on me...i had to stop a few times on way to/from tim's shop cause the gauge was bouncing. then twice it bottomed out on me. i checked all possible cause i knew of. oil level is good and all..so we think its the gauge.
    and the triple pillar is already mounted. :(
    i have personally had to push cars off of the starting line do to bad electric gauges failing , only because we thought the oil pump failed but to find that it was the gauge, so i say mechanical all of the way...
    Quote Originally Posted by weareweird69 View Post
    the only rule is for the fuel pressure guage, you simply need and isolator... and of course the nitrous gauges...unless it is bottle mount.
  1. FS: Many parts - mechanical, exterior, interior
    By cwh19 in forum Ford Vehicles
    Last Post: 09-22-2014, 06:20 PM
  2. Electrical Questions
    By Tony71502 in forum General Tech
    Last Post: 08-11-2009, 01:14 PM
  3. Electrical issue
    Last Post: 01-02-2009, 07:21 PM
  4. Electrical Help.
    By Rio94gt in forum General Tech
    Last Post: 05-24-2007, 05:51 PM
  5. i have electrical problems too
    Last Post: 05-11-2007, 12:34 PM
