Results 1 to 19 of 19
Thread: timing help!
    Feb 2011
    105
    timing help!
    hay n e one know how to set the timing on a 88 mustang 5.0 . Im replacing my timing and need to know how to set it, if n e 1 know please let me know asap. thanks u can evan call me 412 527 6919 thanks matt
    butler pa
    337
    well you will need a timing light first start by taking out the spout connector locate the number 1 plug wire hook that to the timing light loosen the dissy start engine pull the trigger on timing light watch timing marks on damper stock is 10 deg BTDC i run mine at 12 and run 89 gas remeber the higher you go 14+ thats going to push a lillte and you can only use 91 or higher after your done put the spout connector back in
    Aug 2010
    Greensburg, Pa
    390
    im pretty good at setting timing, ive done it to many of my friends cars and i can help if ya need...if your local i can swing by one night or weekend....
    Daily: 2007 Ford Fusion SE
    Feb 2011
    105
    Man that would be great. I'm in the process of putting it back together. But would appreciate your help I live in Scott twp Carnegie area is that close to where u r.
    Aug 2010
    Greensburg, Pa
    390
    pm me ur address n number n we will set somethin up when ur ready
    So...how r u replacing the timing? Just interested, ya know. Never heard of that one before.
    Feb 2011
    105
    I'm putting on new chain and sproket
    Ohhhhh....so you are replacing your "timing chain and gears". I see. I must ask, what was the reason for doing such a job? Cam swap? These dont usually go bad and when it does, there is more than just that going on. If you just wanted a new set, its a waste. But the distributer does not have to come out for this job.
    Not being a dick, just helping out. The TFI should point roughly at 5:00 once the dist is installed.....with the crank on the "zero" mark and on TDC. Then the car will start. If it does not start, you are out 180*. Make sure the rotor is pointing at number 1 on the cap.
    Feb 2011
    105
    I replaced my intake manifold and exhaust and I was running the car with just headers. And threw the timing out so when I tried to adjust it didn't seem right. So i took off the cover and the chain was really loose so I'm hoping that's all it is
    Quote Originally Posted by matty g View Post
    Negative. A double roller timing chain does not just jump out of time. Did you verify the marks before you took it apart? A chain to jump is physically impossible unless you have serious failure...i.e.broken chain or split block.
    Feb 2011
    105
    To be completely honest I'm not the greatest with engine so not real sure what u mean
    Thats fine. Atleast you can admit it. Mosty knuckleheads slide a cam in and call themselves an engine builder.
    What aspect of that post do you not get? Ill explain it for you a little easier.
    When I say verify the marks, I mean, did you turn the crank over till the marks lined up to see if they were in time. This should have been done prior to removing the set anyways. If the dots matched, you shouldnt have pulled it off. Actually, I always set the balancer mark on the zero mark on the tab before taking anything apart. Then you could have looked at the top and bottom gear after you pulled the cover off....which is a pain in the ass with the oil pan in place...
    Feb 2011
    105
    It would be easy for someone to show me .where u from
    Read my public info...right under my screen name...Carnegie. That should be a requirement for members but some choose to not fill that stuff in.
    Feb 2011
    105
    I also live in Carnegie what will it take for I to come and tell me what I did wrong
    Polar Vortex
    6,031
    Yeah deffinitly, then under that should be our social security numbers as well.
    pm me later.
    Haha. Yeah, really.
  1. Timing Advance 94 5.0
    By J-rod in forum Fox-SN95
    Last Post: 05-18-2014, 12:48 PM
  2. need help timing motor
    Last Post: 06-05-2011, 11:49 AM
  3. need some help with timing please
    By vitaleffects626 in forum The Bar
    Last Post: 02-24-2011, 11:39 AM
  4. 2.3 Turbo Timing HELP!!!!
    By fordandmopar21 in forum Fox-SN95
    Last Post: 12-04-2008, 03:03 PM
  5. Timing Problems, Help!!!!!!!
    By ArmyWarrant in forum Fox-SN95
    Last Post: 05-17-2008, 09:37 PM
