hay n e one know how to set the timing on a 88 mustang 5.0 . Im replacing my timing and need to know how to set it, if n e 1 know please let me know asap. thanks u can evan call me 412 527 6919 thanks matt
well you will need a timing light first start by taking out the spout connector locate the number 1 plug wire hook that to the timing light loosen the dissy start engine pull the trigger on timing light watch timing marks on damper stock is 10 deg BTDC i run mine at 12 and run 89 gas remeber the higher you go 14+ thats going to push a lillte and you can only use 91 or higher after your done put the spout connector back in
im pretty good at setting timing, ive done it to many of my friends cars and i can help if ya need...if your local i can swing by one night or weekend....
Daily: 2007 Ford Fusion SE
1991 LX 5.0 5speed- lowered, mach1 wheels, trickflow intake, boss inc style pro cowl hood, 3.73s
Man that would be great. I'm in the process of putting it back together. But would appreciate your help I live in Scott twp Carnegie area is that close to where u r.
pm me ur address n number n we will set somethin up when ur ready
So...how r u replacing the timing? Just interested, ya know. Never heard of that one before.
I'm putting on new chain and sproket
Ohhhhh....so you are replacing your "timing chain and gears". I see. I must ask, what was the reason for doing such a job? Cam swap? These dont usually go bad and when it does, there is more than just that going on. If you just wanted a new set, its a waste. But the distributer does not have to come out for this job.
Not being a dick, just helping out. The TFI should point roughly at 5:00 once the dist is installed.....with the crank on the "zero" mark and on TDC. Then the car will start. If it does not start, you are out 180*. Make sure the rotor is pointing at number 1 on the cap.
I replaced my intake manifold and exhaust and I was running the car with just headers. And threw the timing out so when I tried to adjust it didn't seem right. So i took off the cover and the chain was really loose so I'm hoping that's all it is
To be completely honest I'm not the greatest with engine so not real sure what u mean
When I say verify the marks, I mean, did you turn the crank over till the marks lined up to see if they were in time. This should have been done prior to removing the set anyways. If the dots matched, you shouldnt have pulled it off. Actually, I always set the balancer mark on the zero mark on the tab before taking anything apart. Then you could have looked at the top and bottom gear after you pulled the cover off....which is a pain in the ass with the oil pan in place...
It would be easy for someone to show me .where u from
I also live in Carnegie what will it take for I to come and tell me what I did wrong
