guys with carbs in foxes what cable are you using is there a lokar part number that works best ? thanks
any reason you don't want to use a 79-85 stock cable?
no i havent even checked on those are they available ?
pretty sure just a 4 cyl efi cable
88 GT...and some boost
I have a used Carb cable if your interested, Troy.
If you can find one from the 79-85 also snag the bracket the cable attaches to, that attaches to the intake, this will make things a lot easier.
im kinda jumpin in this thread late but where could i get a throttle cable or could i modify my stock one, im converting from a 5.0 efi to a 306 with a carb
1991 Mustang 5.0 5speed
2012 Boss 302 Race Red #2393
2014 Tacoma 4.0 4x4 6speed
I converted a Fox from EFI to carb several years ago & was able to get a throttle cable from Advance Auto, then just made a bracket to bolt to the intake
ok so if i just go there and order a t cable for a carbed fox and get one of those spectre brackets it should work?
Late to the game...you know you should've called me, Troy.
Get a cable for an in line 6 cyl Mustang. Loop it to get it to line up. Don't try to s-bend it, because the radius is too tight. Come look at my car if you have any questions.
i'll look for my 4cyl on e and see if it works then go from there
