Results 1 to 12 of 12
Thread: throttle cable question
    guys with carbs in foxes what cable are you using is there a lokar part number that works best ? thanks
    NEWB 83dropboy's Avatar
    West Mifflin, PA
    113
    any reason you don't want to use a 79-85 stock cable?
    no i havent even checked on those are they available ?
    Petersburg,PA. 16669
    816
    pretty sure just a 4 cyl efi cable
    88 GT...and some boost
    Mt Pleasant, PA
    4,905
    I have a used Carb cable if your interested, Troy.
    West Mifflin, PA
    113
    If you can find one from the 79-85 also snag the bracket the cable attaches to, that attaches to the intake, this will make things a lot easier.
    i'll be touch lou thanks
    Member Ckelly91lx5.0's Avatar
    Mar 2012
    Houston, PA
    95
    im kinda jumpin in this thread late but where could i get a throttle cable or could i modify my stock one, im converting from a 5.0 efi to a 306 with a carb
    1991 Mustang 5.0 5speed
    2012 Boss 302 Race Red #2393
    2014 Tacoma 4.0 4x4 6speed
    formerly Nsty98LS1
    Jun 2008
    Lilly, PA
    549
    I converted a Fox from EFI to carb several years ago & was able to get a throttle cable from Advance Auto, then just made a bracket to bolt to the intake
    '13 IOM Camaro 2SS/RS: 3 pedals & needing a driver mod
    Mar 2012
    Houston, PA
    95
    ok so if i just go there and order a t cable for a carbed fox and get one of those spectre brackets it should work?
    I drive the Fairmont snailmont5oh's Avatar
    130
    Late to the game...you know you should've called me, Troy.
    Get a cable for an in line 6 cyl Mustang. Loop it to get it to line up. Don't try to s-bend it, because the radius is too tight. Come look at my car if you have any questions.
    i'll look for my 4cyl on e and see if it works then go from there
  1. WTB: Fox throttle cable and bracket
    By sinful rides in forum Ford Parts
    Last Post: 08-15-2014, 09:38 PM
  2. wtb throttle cable
    By silvernotch in forum Ford Parts
    Last Post: 03-07-2010, 10:52 AM
  3. WTB: throttle cable and hoses
    By 97LaserRed in forum Ford Parts
    Last Post: 04-20-2009, 01:54 PM
  4. Throttle cable
    By eddmann55 in forum Ford Parts
    Last Post: 01-22-2008, 10:22 PM
  5. 5.0 Throttle Valve Cable
    By 65 Fastback in forum Fox-SN95
    Last Post: 11-26-2007, 12:49 PM
