Just bought a 95 Cobra. Car came with two Cobra R hoods, both have some damage, wanted to see if anyone had a red hood laying around to put on before I fix either one.
2014 M235i (wife's)
1964 Ford F-100
also looking for a mint driver side fender.![]()
1969 Camaro restomod/project
1967 camaro
2011 mustang procharged
93 reef blue notch blk/int
92 calypso notch blk/int
86 t-type
1972 chevelle project
95GT bone stock 5.0 with ram clutch and billet steel flywheel, 8.8 with rebuilt clutches and 3.73's, sve wieht jacker lower arms, new busihings, new brake hoses, new brake lines, strange enginiering shocks and struts, 255lph fuel pump, mac stain less exhust, all undercoated with por-15 and eliminated every spec of rust from firewall to tail pipe
now its time to crack into the motor portion of the build and try to crank out some power worth talking about
The SN95's look SICK with the 2000R hood IMO
I've got a brand new 00R hood for SN95's in primer ready for paint.
Chris
2016 Chevrolet Volt
2010 Jetta TDi Cup Edition
1964 Lincoln Continental
Both hoods can be fix with some time and skill.
1967 camaro
86 t-type
I have a white stock95 cobra hood, the gel coat on the. Front edge of the hood was worn through it was very minor its fixed and jus needs painted. $125
