Results 1 to 5 of 5
Thread: 331 Shortblock less than 20 miles
    Member mlowry1260's Avatar
    Caledonia, Ontario
    620
    I've decided to sell my existing 331 since I just purchased a larger motor. The motor has less than 25 miles, local break in & EFI tuning. I used all quality parts & had the machine work done by a reputable shop. I have a way more than 2 times the asking price invested.
    1990 production roller block
    hot tanked & shot-peened
    new cam bearings, galley & freeze plugs
    bored .030" over & torque plate honed
    block was squared & machine to zero deck height
    mains lined bored & honed
    balanced rotating assembly to 28 oz.
    Diamond 2618 forged piston, TW valve notches
    Sealed Power moly rings file fit
    Scat 4340 I-beam rods with ARP cap-screws
    Scat 9000 cast steel 3.25" stroke crank
    Clevite H-series rod & main bearings
    ARP main studs
    canton windage tray
    canton 7-qt. street/strip oil pan
    ARP head bolts
    Melling 10687 performance oil pump & hardened drive shaft
    Romac SFI 28 oz balancer
    FRPP billet steel flywheel 157t (5.0)
    The machine work was done at ICS Automotive Machine at 385 Rochester Rd, Pittsburgh, PA. This shop has done work for mikeymustang and he can attest to their attention to detail. I finished the motor last fall just after the race season. I'm sure Mike will tell how the car ran as he was in the passenger's seat tuning on the laptop. No junk parts & good machine work. I can supply pictures of the motor going together. I'll start the car & record some video before I pull it out of the car tomorrow.
    I know some will see this & say you can buy the same thing at DSS or somewhere for less money. Well, go right ahead. If you want to believe that their mass produced motor is put together as well, so be it. I have all receipts & documentation. Add the right cam, heads, induction & exhaust system & make 400+ rwhp reliably.
    Asking $2300
    Mark Lowry
    Senior Member 6987stangs's Avatar
    VALENCIA,PA
    687
    Bob Does Do Great Work. He Does The Machine Work For Me And 383taman
    shaler,pa
    1,010
    Yea Bob is a personal friend and gr8 guy. Does top notch work. My car can prove that. ICS rule (IMO)
    Caledonia, Ontario
    620
    SOLD!!!
    Mark Lowry
    Bridgeville
    1,278
    is bob my motor work guy also >? lol if so he does a damn good job on the punisher
  1. 331 Stroker
    By benny89lx in forum Fox-SN95
    Last Post: 05-11-2011, 05:18 PM
  2. low millage 94 gt with 331
    By yeahloh95 in forum Ford Vehicles
    Last Post: 10-30-2010, 07:54 PM
  3. 2003 Cobra shortblock 19k miles
    By ModularMike in forum Ford Vehicles
    Last Post: 10-06-2010, 09:49 PM
  4. New best for my 9:1 compression NA 331...
    By Killercanary in forum Drag Racing
    Last Post: 11-24-2008, 11:29 PM
