i think its 50 lbs heavier but saves 125 lbs of sprung weight
Couple updated photo's...removed the rear wing...added 3/8" spacers in the rear....switched to a "quiet" borla polished exhaust.....
Looks nice John!
Any pictures of how you cut the trunk floor for the subframe bracket bolts? Did you just use a hole saw?
Thanks Ron....
Dan,
I used a punch to dent the floor to locate the holes. I ended up using an angle grinder and cutoff wheel and made a square hole...then rtv'd some sheetmetal over top.
