Results 1 to 20 of 26
Thread: Just bought a new cobra.. and it has problems
    Junior Member
    Mar 2012
    7
    Hi, i Just bought my first Mustang and it happen to be a Whipple Cobra, we bought the car out in Dayton Ohio and drove it back. On the way home we stopped for gas and i noticed antifreeze leaking. we popped the hood and antifreeze was bubbling out from the cap on the Black tank on the right. But when driving the car it went fine. We got home and it happened again. theres no sign of smoke from the exhaust, and my one friend said he saw oil with in the antifreeze. The fans didnt seem to come on either and the car didnt over heat until we made it all the way home and then it only took a short drive maybe 3 min and it started to over heat. Could a head gasket be messed up? temperature gauge stuck? Fans not working properly? i just don't know what to do. Also any recommendations for someone who could look and found out?
    Many Thanks in Advance,
    Lizik9
    Polar Vortex
    6,031
    Deff. head gasket. Alot of shops can test for hydrocarbons in the coolant. Where are you from?
    Kittanning/Butler
    1,055
    Welcome to SCS, In the Pittsburgh area you have a couple different options for great shops to take a look at it.
    Street Lethal Performance - New Castle, Pa
    Wolfpack Speed - Moon twp, Pa
    They all have a ton of experience with Terminators. Do you have any of the receipts for the work that was done or have the dyno sheet? It is not uncommon for the fans to stop working on the Terminators. There are quite a few write ups on svtperformance.com about it that I have read. Definitely get it looked at by a reputable shop and go from there. There are also a ton of guys on here more knowledgeable than I am that might be able to help you out. Best of Luck. Post some pics of the car!
    Senior Member stevec5ws6's Avatar
    Feb 2011
    289
    Welcome sorry about your problems.
    Junior Member
    Mar 2012
    7
    I'm located in Elizabeth PA, about 20-30min south of downtown Pittsburgh, does anyone have a suggestion on we're to take it?
    Jun 2007
    N. Huntingdon
    1,596
    If it's got an electric water pump, make sure it's wired correctly. The retards that did the work on my first GT before I bought it ground it to the fuel rail.
    Chris
    2016 Chevrolet Volt
    2010 Jetta TDi Cup Edition
    1964 Lincoln Continental
    Quote Originally Posted by Lizik9 View Post
    Do you not like any of the shops mentioned in post #3?
    Junior Member
    Mar 2012
    7
    I didn't even see them actually, But I don't have receipts for the extra parts the guy put on, I have a list of things that he said were on it. I just need someone that can find anything and everything wrong with it,
    Brookline
    2,897
    Yea the fans are notorious for breaking down on the terminators... I would definitely get it out to a shop for some testing to see what is up with it.
    Junior Member
    Mar 2012
    7
    I think it mite be a few things wrong with it. I'll look into which place to send it, thank you Guys very much for all the help. I appreciate it a ton.
    If you don't already have AAA Plus ( up to 100 miles free towing ) I'd get it now. You'll have to wait 10 days or so from the time you join until you submit a "claim" to flatbed the car to one of the shops noted. Still, it'll be worth the cost. Definitely don't drive it any additional distance in case it overheats again.
    wanna race ? SUPRAGATES's Avatar
    pittsburgh pa
    100
    Sorry about your luck Ryan. I went to see this car at his house and one of the catch cans was filled with creamy brown oil almost looked like a iced cappuccino from starbucks. Figured it was a blown HG but was hoping not ! Hope you get this resolved with the fraudulent seller that lied to you.
    94 Supra 6speed | 714RWHP | SP74GTS | SP FUEL SYSTEM | E85 | MAP-ECU | tuned by ME | GREDDY SP1 | VOLK GT-C | HKS COILOVERS | 11.21 @ 139 |
    2003 KB cobra - 564rwhp ( sold )
    Brookline
    2,897
    Where did you find the car at? Online?
    Junior Member
    Mar 2012
    7
    Yes private seller out in Ohio. And thanks gates I hope the guy gets what he deserves
    pittsburgh pa
    100
    Quote Originally Posted by Terminated View Post
    It was on svtperformance
    Polar Vortex
    6,031
    That sucks. Usually svtp is pretty solid on issues like this. Report this to lightning larry on there. Maybe they can post a sticky about this transaction.
    Somerset Co.
    2,907
    I'm pretty sure he's no longer a Mod there.
    Kittanning/Butler
    1,055
    I try to ban myself from svtperformance, every time I get one I want something else! Sonic blue lightning would look real good beside the Cobra
    fairmont,WV
    1,352
    Try SID297.....that's Travis and he owns the site.
    XXX RWHP
    XXX RWTQ
    4,321
    Lizik9
    Sorry to hear about your troubles but if you leave me a message at the shop or email your contact info I will call you ASAP. Slammed with work but I will do what I can to help you! Good luck either way!
    Mike
  1. Sold my Cobra and bought this
    By 95Vert in forum Pictures & Videos
    Last Post: 07-06-2013, 06:31 PM
  2. having problems with my 03 cobra
    By chargedcobra03 in forum SN95-New Edge
    Last Post: 05-28-2013, 03:59 PM
  3. 03-04 cobra owners....fan Problems??? I've broke 2 in 5K miles
    By Freakingstang in forum SN95-New Edge
    Last Post: 10-24-2012, 02:49 PM
  4. 2003 cobra sterring problems
    By regan in forum S197
    Last Post: 03-31-2008, 06:41 PM
  5. So I bought Dans Cobra tonight....
    By Cam99 in forum The Bar
    Last Post: 09-05-2007, 01:48 PM
