Results 1 to 5 of 5
Thread: FS: Comp Cams Hydraulic Roller Cam & Lifters. 280 / 290 H
    Mt Pleasant, PA
    4,905
    This kit is brand new in the box, the plastic wrapping has never been removed.
    350.00
    Sent from my MZ609 using Tapatalk
    Will these lifters work in an older Windsor block ?
    Mt Pleasant, PA
    4,905
    Not sure if they can be Retro fitted or not, this kit is set up for the wishbone lifter retainers.
    Old School 5.0 ERHsn95's Avatar
    Apr 2011
    pgh
    52
    cams
    im not as well educated on engine building yet as i would like but what would this cam do for a mostly stock 5.0 with a trickflow intake and 30 lbs injectors possible some sort of gt40 heads if i can find a good set cheap just curious
    95GT bone stock 5.0 with ram clutch and billet steel flywheel, 8.8 with rebuilt clutches and 3.73's, sve wieht jacker lower arms, new busihings, new brake hoses, new brake lines, strange enginiering shocks and struts, 255lph fuel pump, mac stain less exhust, all undercoated with por-15 and eliminated every spec of rust from firewall to tail pipe
    now its time to crack into the motor portion of the build and try to crank out some power worth talking about
    Mt Pleasant, PA
    4,905
    Quote Originally Posted by ERHsn95 View Post
    Your going to need a pretty good set of heads and supporting parts for.this Cam. I don't think p heads would work, maybe some of.the 5.0 guys on here could chime in.
  1. FS:comp cams solid roller cam/solid roller lifters
    By 1badnotch in forum Ford Vehicles
    Last Post: 01-17-2011, 05:45 PM
  2. WTB:stout hyd roller cam;TFS 3,anderson,comp,etc
    By 1badnotch in forum Ford Parts
    Last Post: 11-12-2010, 09:35 PM
  3. Comp Cams XE268H-14 Cam Set
    By Mitternacht in forum Ford Vehicles
    Last Post: 03-29-2009, 04:19 PM
  4. 16 Ford hydraulic roller lifters
    Last Post: 03-05-2008, 03:19 AM
  5. Wtb Chevy Roller Cam And Lifters
    By chuck94 in forum Ford Parts
    Last Post: 06-18-2007, 06:44 PM
