Results 1 to 16 of 16
Thread: pulling my motor from my 88 gt
    Feb 2011
    105
    OK any know if its a hard project to pull a motor from a 88 fox. I'm pulling my motor so i can paint the block and the bay. I'm also planning on smoothing the fender wells .and also cover the holes where the fender well intake would do. Any info would greatly appreciated thanks
    Squiggles.......... Erics89GT's Avatar
    Aug 2010
    Greensburg, Pa
    390
    its not real difficult...quite easy to be honest.....the wiring harness can flip over and be held down on the windshield by a wiper and disconnect the exhaust and tranny along with the hoses and take out the fan n shroud....pretty much it....
    Daily: 2007 Ford Fusion SE
    1991 LX 5.0 5speed- lowered, mach1 wheels, trickflow intake, boss inc style pro cowl hood, 3.73s
    NEWB 83dropboy's Avatar
    West Mifflin, PA
    113
    Well, what other motors have you pulled?
    Last one I pulled we took the motor and tranny out of the top together, wasn't that hard. Had the front of the car about a foot off the ground.
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Pulling the motor and getting the engine bay cleaned/prepped is easily an evening job.
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    Aug 2010
    Greensburg, Pa
    390
    most motors i pulled were chevys....couple fords but the foxbody is prob the easiest ive done....lotta room for yankin a motor
    Feb 2011
    105
    Thanks guys for all the info. My biggest thing is I'm not the best gear head just learning alot of things.well I appreciate all the info please keep it coming n e thing that would make this job easy for memo will great fully appreciate it thanks
    Make sure when pulling, the front of the puller isn't in contact with the bumper cover if the handle faces the car. Ask me how I know.
    Brookline
    2,897
    I don't know shit about pulling a motor and I could probably pull a 5.0 out of a fox in a couple hours.
    West Mifflin, PA
    113
    Do you have the tool to disconnect the fuel lines?
    Try to relieve the fuel pressure too, I think the shrader valve on the rail will do the trick.
    That is the only 'special tool' required that I can think of.
    I also found this online, may be helpful if you never pulled one before.
    I have pulled about 10 of these, sometimes with the tranny connected, sometimes, just the motor,
    I prefer to pull/replace the motor and tranny out together, less crawling on the ground later.
    http://www.pomoforacing.com/tech/EnginePull.pdf
    I have bad luck. 95V6's Avatar
    Apr 2010
    South Hills
    3,579
    With the right tools,space and a engine hoist it shouldn't be bad. Extra set of hands would be best.
    -Barry
    Feb 2011
    105
    Quote Originally Posted by Terminated View Post
    Well u must be a pretty impressive fella with a wrench see me um just learning thanks
    Feb 2011
    105
    For all the guys that posted useful information thanks i appreciate it alot
    Brookline
    2,897
    Quote Originally Posted by matty g View Post
    That wasn't meant to be a shot at you, just saying that it's relatively easy and straightforward.
    Feb 2011
    105
    O its kool man . I just don't know much at all when it comes to motors and things like that. But it was a stereo and some interior I would be in great shape.
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    I think pulling an engine is easier than installing a stereo. Different skill set, but not harder skill wise. Just take your time, put bolts in plastic bags that are labeled until you know what each one is (after a few times you will), take your time and you will be fine. Take pictures of each step if it helps you as well.
    2014 M235i (wife's)
    1964 Ford F-100
    Feb 2011
    105
    I will do that thanks
  1. Pulling heads
    By 94svtcobra in forum Fox-SN95
    Last Post: 10-09-2009, 01:40 PM
  2. Replies: 0
    Last Post: 01-07-2009, 12:08 PM
  3. Pulling engine with LT Headers
    By Mitternacht in forum S197
    Last Post: 06-23-2008, 07:13 PM
  4. Buske portable pulling tower
    By JC Turbo in forum Ford Vehicles
    Last Post: 01-03-2008, 08:38 PM
