Results 1 to 13 of 13
Thread: motor loses RPMs
    Junior Member
    Jul 2011
    13
    motor loses RPMs
    5.0 liter in a 93
    I am having some major issues and I'm not sure on where to start. With the car just sitting there idling (idles rough, almost like it has a huge cam) and then rev'ing the motor up I lose RPM. I can rev it up to 3000 rpm and it'll drop to 2500 then right back up to 3000 and back down to 2500 etc etc, I changed the ignition module on the distributor and that didn't fix it, We noticed the car has a fuel regulator on it too which I'm hoping to take off soon but figured it wouldn't hurt to see what you guys thought.
    Thanks in advanced
    Aug 2010
    washington,pa
    201
    i would check the fuel pressure with a gauge and see what it does when you are reving it. also i would check the tps voltage also.
    Polar Vortex
    6,031
    vacuum leak? Dirty mass air sensor?
    Aug 2010
    Greensburg, Pa
    390
    bad iac sensor too
    Daily: 2007 Ford Fusion SE
    Polar Vortex
    6,031
    Quote Originally Posted by Erics89GT View Post
    bad iac sensor too
    yeah, try cleaning it with some carb and choke cleaner. if the plunger moves freely then it's not stuck.
    Member torqueboxer's Avatar
    white oak, pa
    638
    Ill go fuel pump/ filter.
    Brookline
    2,897
    I would do one step at a time and see if it works. Don't start doing a bunch of the above mentioned things cus then you don't know which one will/won't fix it.
    My guess is something in the air delivery/vacuum.
    Sep 2007
    Dayton PA
    3,795
    Ive rode in the car with him, hes losing ignition somewhere....he changed the ignition module already...the tach literally drops off when it starts to stumble.
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    Polar Vortex
    6,031
    Is it happening under load?
    Junior Member
    Jul 2011
    13
    Yes under load. Suppose to be a nice weekend so ill hopefully have some time to mess with it.
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Watching with interest....my HO T-bird is doing almost the exact same thing!
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    Junior Member
    Jul 2011
    13
    If anyone cares, I had a bad distributor, my buddy has a 5.0 in storage that we took it off of and now the car runs great.
    Try'n for 12's shockstang's Avatar
    morgantown, wv
    277
    Glad you got it figured out. Those kinds of problems drive me crazy.
    No Burnout Bill
  1. mustang breaks up at 4000 rpms
    By chuck94 in forum Fox-SN95
    Last Post: 06-21-2009, 12:28 PM
  2. getting hesitation when shifting at higher rpms
    By DMmustangLX in forum Fox-SN95
    Last Post: 05-13-2009, 05:12 PM
  3. A fellow soldier loses his life.
    By ArmyWarrant in forum The Bar
    Last Post: 02-25-2009, 10:27 PM
  4. Pics of RPMS 2003 Lightning
    By BoneCrusher in forum Pictures & Videos
    Last Post: 05-12-2007, 11:22 PM
  5. after 6 months the WRX finally loses
    By TBone7281 in forum The Bar
    Last Post: 05-08-2007, 10:42 PM
