Results 1 to 5 of 5
Thread: Trouble passing emissions
    Apr 2010
    South Hills
    3,579
    I'm havering problems passing inspection, mainly emissions.
    Here's the problem:
    The sealed bearing on the throttle body is leaking past the IAC. The o ring on the mass air flow sensor needs replaced. And the mass air needs to be compatible with a new throttle body. Thus running lean. It threw a code, both banks running lean and no vaccume leaks. He sprayed carb cleaner around the IAC both 02 sensors came online and it richen'd up. He had it hooked up to a laptop and it showed everything else was great, great fuel pressure and all injectors good.
    So I have to a new throttle body, mass air sensor, and I'm getting rid of the junk cold air that came with the car. I'm going to buy the stack cold air and tuner combo from AM, kill two birds with one stone. As for throttle body my C&L is for 75mm TB just going with the cheapo from AM. As for mass air sensor I have no idea.
    -Barry
    Member torqueboxer's Avatar
    white oak, pa
    638
    Whats your question?
    Apr 2010
    South Hills
    3,579
    Question is does this sound right?
    -Barry
    unplug the battery...drive it for 50 miles and take it back.....
    do you have long-tube headers in place of the fatory manifolds?
    Apr 2010
    South Hills
    3,579
    No LT's.
    We did and the CEL came back on.
    -Barry
  1. Emissions Hookup ?
    By SlowSix in forum The Bar
    Last Post: 04-24-2013, 08:34 PM
  2. This made me laugh so I'm passing it on.
    By KeystoneJohnny in forum Pictures & Videos
    Last Post: 03-19-2012, 03:11 PM
  3. CA Emissions???
    Last Post: 09-03-2009, 08:35 AM
  4. Replies: 0
    Last Post: 02-09-2007, 01:39 PM
  5. Emissions
    By MellowYellow03 in forum The Bar
    Last Post: 09-21-2006, 10:56 PM
