Results 1 to 20 of 29
Thread: bore limit for 351 W
    Member k7cobra's Avatar
    Oct 2010
    penn hills pa
    89
    whats up guys i for got i had a built 351 w at the machine shop. first let me tell you guys what my plans are im looking for a rolling body sn95 to build a drag car out of i dont want to do a big block swap just because i like small blocks. i want to punch my 351 out to a 427 or more what is the max i can go im looking to make around 600 to 700 rwhp i know that the motor will take it. what do you guys think
    What year is the block?
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    You can't "punch out" a 351 to 427. Has to be done with a stroker crank. Not sure how far you can go, certainly not above .060.
    2014 M235i (wife's)
    1964 Ford F-100
    Oct 2010
    penn hills pa
    89
    im not sure the year on the block i think its early 90s late 80s motor was given to me im ether going to bore this motor or im going to buy a 427 ford racing small block
    Senior Member TJH64's Avatar
    Delmont PA
    320
    Have the block sonic checked. This will give you a definite answer on how far you can safely overbore.
    Trafford, Pa
    2,308
    Quote Originally Posted by k7cobra View Post
    Are you planning on doing this NA or with boost/spray?
    2014 M235i (wife's)
    1964 Ford F-100
    You should spend 2 weeks reading on teh interwebz about SBF's or find an engine builder you trust to build the engine for you.
    Member torqueboxer's Avatar
    white oak, pa
    638
    .040 max on the bore, no 427, stick with a 4" stroke crank. And if na is the plan save up about 10-13,000 to achieve your goals
    Oct 2010
    penn hills pa
    89
    nope im going to run NA. the motor runs 11s as is i just want to put it in to the low tens high 9s. im trying to avoid doing a big block swap but if its going to cost me to much ill just buy one of my father in laws big block race car motors
    Trafford, Pa
    2,308
    So basically you are trying to make NASCAR power levels on a budget? Even a 427 at 14 to 1 would have to turn in the neighborhood of 8,000 rpm to attain anywhere near the kind of power levels you are talking about, which means the factory block isn't going to be adequate. You will likely be in the 15K range, easily. Or you could just spray it. What mods are done to the engine currently to run 11s? What does it run 11s in?
    A big block swap is another thread, not exactly an easy undertaking either.
    2014 M235i (wife's)
    1964 Ford F-100
    South Hills, PA
    4,052
    Omg i cant take it anymore
    Trafford, Pa
    2,308
    2014 M235i (wife's)
    1964 Ford F-100
    South Hills, PA
    4,052
    As soon as i saw the word punch out i was done.
    Oct 2010
    penn hills pa
    89
    its ok my wording is horable
    can i put that in my sig? :D
    Oct 2010
    penn hills pa
    89
    why not and thanks for pointing that out. lol this day has gone to hell
    700 rwhp N/A on a budget?
    With a 351w stock block?
    1969 Camaro restomod/project
    1967 camaro
    2011 mustang procharged
    93 reef blue notch blk/int
    92 calypso notch blk/int
    86 t-type
    1972 chevelle project
    Brookline
    2,897
    Isn't this like the 8 or 9th proposed motor option for the car? Maybe you're better off leaving well enough alone?
    Oct 2010
    penn hills pa
    89
    no this is not going in my cobra as of right know there is no budget for the build im thinking about this is going to be for a full blown race car
    South Hills, PA
    4,052
    Quote Originally Posted by went9s View Post
    Best two statements in thread. Threads like this is why scs is dying and the young bloodz have taken over? Whats next thread? How much hp can a stock block handle or i know how do i get traction?
  1. standard bore size of a 98 4.6
    Last Post: 09-19-2011, 10:02 AM
  2. Stock bore 302 block
    Last Post: 03-10-2010, 07:28 PM
  3. WTB 74 or earlier virgin bore 351w block
    By 94svtcobra in forum Ford Parts
    Last Post: 08-25-2009, 10:47 PM
  4. Race gas compression limit?
    By Silverhatch in forum General Tech
    Last Post: 04-16-2009, 11:42 PM
  5. New Kenne Bell Big Bore Blowers
    By mlowry1260 in forum SN95-New Edge
    Last Post: 09-15-2006, 05:14 PM
