Results 1 to 20 of 29
Thread: CEL is back.....help
    Squiggles.......... Erics89GT's Avatar
    Aug 2010
    Greensburg, Pa
    390
    91 lx 5 liter 5 spd....tonight while coming back from car show the cel came on.....it came on when im on the throttle over 1500rpms but goes out when i let off....if i run through the gears, then putz around for a few min is doesnt come on...
    what do you suspect....o2 sensor, iac, maf, or what....im stumped
    Daily: 2007 Ford Fusion SE
    1991 LX 5.0 5speed- lowered, mach1 wheels, trickflow intake, boss inc style pro cowl hood, 3.73s
    I have bad luck. 95V6's Avatar
    Apr 2010
    South Hills
    3,579
    Possible vaccume leak? Mine came back on tonight, I disconnected the battery for about 30 seconds and I went off and is still off.
    -Barry
    2003 Ford Mustang Dark Shadow Grey 4.6L GT
    2004 Ford F-150 Super Crew Dark Shadow Grey 5.4L
    Polar Vortex
    6,031
    use a scan tool to pull the code. that will solve everything rather than guessing.
    Apr 2010
    South Hills
    3,579
    Agreed. Take it to advance auto, they will let you hook it up for free and look up what the code is.
    -Barry
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    None of the parts stores have scanners that read pre-OBD II cars. Didn't when I went anyway.
    2014 Mustang GT Stock and for sale
    2014 M235i (wife's)
    1964 Ford F-100
    Apr 2010
    South Hills
    3,579
    Quote Originally Posted by Mark Aubele View Post
    They read mine.
    -Barry
    Your mom cwh19's Avatar
    May 2009
    Greensburg
    1,383
    Quote Originally Posted by 95V6 View Post
    They read mine.
    Your car is OBDII. Foxes are OBDI. Unfortunately part stores don't pull codes for OBDI cars.
    OP do you have a scanner? They are pretty easy to use once you figure out the flashing light thing.
    The best former Rodeheaver's Hot Rod employee ever.
    15gt
    Premium - Performance Pack - Recaros
    94gt
    410w - faceplated t56 - s478 - Gone
    Apr 2010
    South Hills
    3,579
    Quote Originally Posted by cwh19 View Post
    Ah, older cars are OBDI.
    -Barry
    Aug 2010
    Greensburg, Pa
    390
    i cant pull a code did tht before n it said system ok its only when im driving it goes on when throttle is down but as the rpms climb is goes on n off when in neutral i rev it the light wont come on
    Aug 2010
    washington,pa
    201
    check the connection at your tb and your air intake hose. it might be sucking air right there and causing it to come on. if not that i would go with a vacuum leak
    Aug 2010
    Greensburg, Pa
    390
    but when i put the new cobra intake on, i put 1 new o2 sensor on cuz the other was good and i put a new pcv on, but the light never came on and i put over 500 miles on my new setup....im thinkin 02 sensor but it doesnt run like it has a vacuum leak
    Aug 2010
    Greensburg, Pa
    390
    my buddy has one for his 94 n we used tht hence the reason i cant get a code
    Ford ODB-I scanners are only ~$20 last I checked- it's probably worth having around if you're doing a lot of work.
    [ame="http://www.amazon.com/Equus-3145-Ford-Digital-Reader/dp/B000EW0KHW/ref=sr_1_1?ie=UTF8&qid=1338067010&sr=8-1"]Amazon.com: Equus 3145 Ford Digital Code Reader: Automotive@@AMEPARAM@@http://ecx.images-amazon.com/images/I/415HwC1DWAL.@@AMEPARAM@@415HwC1DWAL[/ame]
    2005 Mustang GT
    11.2 @ 123
    I have the one shown in the picture above. It's in wifey's convertible since it's the only thing I have left with an EEC
    Aug 2010
    Greensburg, Pa
    390
    like i said it wont pull a code just sitting ther with a scanner its only when driving
    95v6 is always a great help glad he knows what hes talking bout
    Polar Vortex
    6,031
    does the light blink on and off when it does come on?
    Aug 2010
    Greensburg, Pa
    390
    yes and sometimes no it will stay on until i am off the throttle
    Polar Vortex
    6,031
    Quote Originally Posted by Erics89GT View Post
    I'm sure someone will correct me if im wrong but I always thought a blinking cel is a missfire in one or more cylinders. It makes sense too because it only seems to happen when you have the car under load, and not in neutral.
    Member 2000GT's Avatar
    Plum, PA
    1,612
    Quote Originally Posted by John4cam View Post
    Ageeed. A bad O2 or somenthing like that would cause a steady CEL - not a blinking one.
  1. Im back!
    By 89 vert in forum Fox-SN95
    Last Post: 06-13-2013, 03:18 PM
  2. The Z/28 is back !
    By Troll in forum Camaro
    Last Post: 04-01-2013, 12:28 PM
  3. A little help please, CEL.
    By Jivepepper in forum SN95-New Edge
    Last Post: 09-01-2008, 06:50 PM
  4. Replies: 29
    Last Post: 06-18-2008, 09:27 PM
  5. I'm Back!!!!
    By INSANELY CRAZY in forum Pictures & Videos
    Last Post: 12-09-2007, 11:44 PM
