Results 1 to 7 of 7
Thread: What type of suspension do you think is the best?
    Jun 2008
    Bell Acres
    469
    I'm planning on completely tearing apart my chevelle soon and want to replace the horrible stock four-link, coil spring set-up that is so similar to mustangs.
    Instead, I was thinking coil-overs, watts-link, and parallel upper and lower control arms(to get rid of that bind). Up front do coilovers and better control arms in the SLA set-up. Not to mention all the misc pieces like sway bars. This includes replacing the stock rear crossmember and putting in a crossmember more suited for whatever suspension type I decide to go with.
    Any thoughts or ideas of a better suspension set-up. I don't want a torque arm and a panhard is not as good as a watts imo.
    robinson
    1,091
    what are you trying to do with the car? more handling or straightline?
    /twocents
    Take a look at Global West Suspension. I have a bunch of their stuff on my '66 Mustang and love all of it - from the front UCAs coils and sway bar to the subframe connectors to the rear leafs and Del-Alum leaf bushings.
    http://www.globalwest.net/64-72-chev...-packages.html
    Jun 2008
    Bell Acres
    469
    Handling. Kinda along pro touring lines. I don't like the stock 4-link because of the way the upper control arms are... just like on a fox. That's why I'm considering chopping into the frame and setting it up with a watts link and parallel control arms.
    I posted to get thoughts on other suspension set-ups that put the stock 4-link/coil spring to shame.
    I've already got Hotchkiss sway bars, upper and lower control arms in the rear, 2 inch drop spindles, 4 wheel power disc, Hotchkiss 1 inch drop springs, and global west upper and lower front control arms. Also some crappy KYB shocks.
    I've got quite a bit of unsprung mass using a Dana-60 rear end. That I think will get different gears(go from 4.11 down to something smaller) and replace the Detroit Locker with a Posi unit. It's got Strange S/S 36 spline floating axles, also. No c clips here.
    Jun 2008
    Bell Acres
    469
    Here's what a member on TeamChevelle did with his 70. Cut out the rear cross-member that had coil pockets on it, and fabbed up some new ones to go with parallel control arms and a watts link crossmember. Not to mention custom trans member, boxed rails, and webbing.
    Brookline
    2,897
    ^^^ Wow that looks really great!
    It almost is a shame to hide that gorgeous frame and suspension under the body...
  1. Any bikers.....the pedaling type
    By Dan B. in forum The Bar
    Last Post: 06-22-2013, 07:46 AM
  2. A different type of 4X4 Truck
    By Donstang86 in forum The Bar
    Last Post: 08-25-2011, 04:53 PM
  3. turbo buick gn t type
    By 9secmach1 in forum Ford Parts
    Last Post: 01-29-2010, 10:30 AM
  4. Type of gas in a '66?
    By 65 Fastback in forum General Tech
    Last Post: 09-26-2009, 05:09 PM
  5. what type of shock/strut???
    Last Post: 12-21-2008, 09:54 PM
