Results 1 to 6 of 6
Thread: T56 Pops out of 3rd gear.
    Brookline
    2,897
    Right section? It's bolted to a mod motor so?
    Anyways, I've noticed that, in certain instances, my car will pop out of 3rd gear. It seems to happen most if I am coasting in 3rd and the car gets to around 1000-1500 RPM, sometimes it pops out on its own, but it's more common if I place any pressure on the shifter (MGW Orange). I've never noticed it being hard to shift into 3rd, and it doesn't grind, but it prob. shouldn't be popping out on its own.
    Motor/Trans has 68,500 miles and I definitely don't drive it like a jagoff. It is fine on acceleration and even decel, unless I'm in a specific RPM range. It almost seems like it's just one of those things where you direct shift the trans sans clutch and it's at the right speed, but could there be something else?
    Any thoughts or ideas is appreciated.
    Dan
    Somerset Co.
    2,907
    Do you have the screw stops in the base of the shifter? Your not supposed to use them on a T56.
    Brookline
    2,897
    Came with the shifter in it, but I never thought to look. I'll check it out today and see. I did some Google'ing earlier and they mentioned it on some FBody forums, but they didn't mention what shifter they were usin.
    Apr 2010
    South Hills
    3,579
    Didn't you mention awhile ago you have a spinning metal throw out bearing noise?
    -Barry
    Brookline
    2,897
    Yeah it's a slight TOB whine before it gets warm, if you put your foot on the pedal it goes away. I'm thinking they are unrelated but... guess ya never know...
    Can the TOB whine issue on the T56's be fixed by using a steel bearing retainer like on the T-5s ?
  1. t56
    By ocrowner in forum Ford Parts
    Last Post: 01-16-2015, 11:10 AM
  2. t56 problems
    By k7cobra in forum SN95-New Edge
    Last Post: 02-19-2012, 05:31 PM
  3. Looking for a used tr3650 or maybe a T56
    By Jivepepper in forum Ford Parts
    Last Post: 02-08-2012, 01:14 PM
  4. Pops stang
    By 94svtcobra in forum Pictures & Videos
    Last Post: 05-22-2009, 11:34 PM
  5. T56, crossmember, and driveshaft
    By Smallville in forum Ford Parts
    Last Post: 02-04-2007, 10:43 AM
