Results 1 to 9 of 9
Thread: help!! all advice taken
    Old School 5.0 ERHsn95's Avatar
    Apr 2011
    pgh
    52
    well guys i have an intermitant problem with my 95 gt every time i think i have a fix. it comes back in a week or less it has a crazy surge and backfire at 3000 rpms and the tac bounces every where i cant track the problem down any body have any ideas
    btw i just put new plugs and wires and msd dizzy and coil in thinking it was an ignition issue and that didnt work also i put a new egr valve on and that didnt do the trick. its definatly not a cloged cat becuz i put off road pipes on to test that. im not sure what to do next i love the car i just want it to run right.
    95GT bone stock 5.0 with ram clutch and billet steel flywheel, 8.8 with rebuilt clutches and 3.73's, sve wieht jacker lower arms, new busihings, new brake hoses, new brake lines, strange enginiering shocks and struts, 255lph fuel pump, mac stain less exhust, all undercoated with por-15 and eliminated every spec of rust from firewall to tail pipe
    now its time to crack into the motor portion of the build and try to crank out some power worth talking about
    Aug 2010
    Greensburg, Pa
    390
    IAC maybe....if its surgeing for an idle or loose vacuum.....i know your pain im going thru something similar with my 91
    Daily: 2007 Ford Fusion SE
    Actually a 97
    May 2011
    Scott Twp.
    508
    Does it only happen at 3k rpms? Aftermarket CAI?
    1997 Mustang Gt
    -Automagic
    1957 Cadillac Coupe DeVille
    Sep 2007
    Dayton PA
    3,795
    change the ignition module yet?
    It cant be the IAC it only controls idle if its happening at 3k.....when you say the tach bounces is it realistic, like the engine is just losing RPM or is it erratic?
    03 Torch Red Anni. Ed. Cobra
    01 cobra: traded
    93 LX Modular 4v swap
    Second that tfi problems are a pain. If not check the harness connections for corrosion.
    Polar Vortex
    6,031
    bad ground?
    Tach bouncing is PIP signal. Msd distributers are known for their issues in those cars. Pit a stocker back in and start from there. Tfi also. Try the EXACT one for your car. Also, as John said...ground.
    Apr 2011
    pgh
    52
    Thanks for the replies guys and well its eratic and only happens at three grad or above i havent checked the ground yet but i have been having other spuratic electrical glitches but i was more worried about this issue and was putting checking them out till later but maybe its all part of it i feel stupid asking but wat is the tfi everyone keeps talking about
    Sep 2007
    Dayton PA
    3,795
    its the ignition module. it was on the distributors in the older 5.0s....yours is remote mounted and looked like this....
    01 cobra: traded
  1. 89 GT A/C Advice
    By Abruzzese in forum Fox-SN95
    Last Post: 05-23-2013, 09:59 PM
  2. I need some advice
    By ERHsn95 in forum Autocross & Road Racing
    Last Post: 03-06-2012, 07:34 AM
  3. 94 need advice
    By RogerStout in forum Fox-SN95
    Last Post: 04-14-2011, 11:20 AM
  4. advice here all
    Last Post: 01-30-2009, 09:19 PM
  5. Need advice
    By macs02gt in forum SN95-New Edge
    Last Post: 12-11-2006, 07:08 PM
