Results 1 to 20 of 21
Thread: 5.0 twin turbo build
    i recently found a 5.0 with a blown head gasket computer and harness and a twin turbo set up im planning on buying. Im looking to make as much rwhp as possible with a stock block without blowing it to pieces. Its going in a 84 svo fox body any ideas? Specs? What parts i should buy along with the turbos? The turbos are small garretts
    What are the specs of the car now? If we know what all is done then we can help you choose the next modifications. Is there any budget limit?
    i have till after december to have all the parts. So im not really sure of a budget but it will be a couple of grand and the car so far is just a roller. i have the motor out of a different car it came as a 4 cyl turbo car and im building it into a 5.0 street strip car.
    What year is the engine you have now? Is it completely stock?
    91 with the mas harness and yes it is stock
    South Hills, PA
    4,052
    and you wanted to put my 98mm on this stock engine? lol
    No someone else is looking for a turbo at school I've got the two garrett turbos you put the picture of yours are on
    South Hills, PA
    4,052
    k just checking
    Any help here? Just looking to make a quick little mustang and never messed with building car motors before
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Quote Originally Posted by lawrence2012 View Post
    Just looking to make a quick little mustang......
    What is your definition of quick??
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    Looking from anywhere from 425 to 525 hp
    Member torqueboxer's Avatar
    white oak, pa
    638
    Add any aluminum heads replace intake with any you can find, 42lb injectors, stock cam, 10lbs of boost, add any tuning device you want...400plus hp
    Spencerport, NY
    3,762
    just a thought - is it really worth all of the expense of a TT build to make 500rwhp?? There's got to be way cheaper, way easier ways to make that kind of power...
    2015 Corvette Z06
    - Shark Grey / Kalahari
    Turbo kits actually are the cheap way to make power on old 5.0's. You can make his target power levels with the stock long block and and a bolt on ebay turbo kit which is only around $1000-$1500 then just add your normal supporting mods.
    Polar Vortex
    6,031
    I've heard some horror stories about the cheap kits on ebay. I'll bet street lethal could put a package together on a fox for very cheap, and the quality will be there.
    white oak, pa
    638
    I think he may be trying to learn something about building cars, dropping it off at a shop then writing a check really dosn't allow the op to gain knowledge or have the satisfaction of sayin "I built that "
    Polar Vortex
    6,031
    True.
    87 foxbody mkwood4's Avatar
    Oct 2011
    aliquippa
    190
    true its alot better when you do it yourself. i have more respect for the guys that diy.
    1987 mustang lx/gt
    2010 nissan xterra
    2001 ford f-150 super crew
    yea thats what i want dont know much but willing to learn
    Actually a 97
    May 2011
    Scott Twp.
    508
    A single turbo kit for a fox starts at 3800 at StreetLethal. Not trying to promote, just remember seeing it in another thread. Good luck with your build man.
    1997 Mustang Gt
    -Automagic
    1957 Cadillac Coupe DeVille
  1. 98 GT twin turbo dyno
    By dpstang98gt in forum Pictures & Videos
    Last Post: 04-21-2008, 11:44 PM
  2. Twin Turbo 5.4
    Last Post: 02-17-2007, 11:32 PM
  3. Twin Turbo GT
    Last Post: 09-24-2006, 02:41 PM
