Results 1 to 5 of 5
Thread: Clutch petal feel??
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    Clutch petal feel??
    The clutch petal in the t-bird is starting to feel a little "catchy"...like the cable is not sliding smooth in the liner. Is this a break just waiting to happen?? The wife says it's really stiff but I've been driving it enough that a gradual increase in pressure is not noticeable....and I blamed it on the centerforce clutch and pp.
    Ideas?
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    Check both ends of the cable and see if anything is starting to crack / fray. The cable on my '66 gave me some symptoms back before it broke a few years ago. I was at the strip and I couldn't sit at the line ( clutch in ) without creeping forward. I adjusted it and made it home, but soon after it crapped out. Mine isn't a quadrant-style setup - just a cable adapted to a modified '66 pedal assembly.
    Armagh, PA
    4,331
    Cable looked good at both ends but I put in a new FMS one in this evening.....WHAT A DIFFERENCE! It's like a new car.
    Ahh fuque
    Glad to hear you're all fixed up Dan! So when are you taking the Bird to the strip??
    Armagh, PA
    4,331
    Waiting for the weather to cooperate. It went several passes at 14.0 a couple weeks back...later found out I was shifting too late. Since then it has been HOT! So when the temps and humidity are down some I'll go back. Hope to see 13.80's or better....but if it doesn't, I'm still not going to do anything...it's just fun to drive.
    Ahh fuque
  1. WTB T5, petal assembly and other
    By 92FOX in forum Ford Parts
    Last Post: 03-13-2011, 10:37 PM
  2. sold the truck... feel bad what to do??
    By madmaxin22 in forum The Bar
    Last Post: 09-22-2009, 11:43 PM
  3. ...and this is just how I feel about it...
    By u1arunit in forum The Bar
    Last Post: 01-27-2008, 05:08 AM
  4. Clutch
    Last Post: 08-31-2007, 10:01 AM
  5. Clutch
    By hunter31 in forum SN95-New Edge
    Last Post: 05-05-2007, 11:29 PM
