Results 1 to 3 of 3
Thread: Ford AOD Trick Flow aluminum pan $60.00
    Senior Member roush08's Avatar
    Jul 2010
    North Huntingdon, PA
    438
    Aluminum transmission pan from Trick Flow Specialties. Model number TFS-1007, retails at summit racing for $139.95. Pan is used but in good condition. It increase your fluid capacity on your Ford AOD by 1 qt and is made with aluminum to help with the heat. It is finned and also has a drain plug for easy draining. Was used on a 1987 Ford Mustang with an AOD so would imagine it would atleast fit the 1987-1993 Mustangs with 5.0 litre engines and AOD's. May fit other models / years so please check your specific application. From Summit's website :
    "These Trick Flow® transmission pans are made from cast aluminum. They hold an extra quart of fluid, and are finned to help the transmission dissipate heat, for maximum efficiency."
    Junior Member
    Mar 2013
    1
    aod pan
    Hi any chance you still have aod pan thanks mike
    Jul 2010
    438
    Sorry sold. Thanks
  1. Trick Flow C4 tranny pan
    Last Post: 02-21-2012, 08:38 AM
  2. Ford AOD trans B&M hammer shifter Trick Flow pan
    By roush08 in forum Ford Vehicles
    Last Post: 03-10-2011, 05:56 AM
  3. WTB: C4 Deep Aluminum Pan
    By Dan B. in forum Ford Parts
    Last Post: 05-11-2010, 03:30 PM
  4. Trick Flow Intake
    By 1slow46 in forum Ford Vehicles
    Last Post: 02-08-2010, 08:05 PM
  5. trick flow streetburner?
    By Gray 5.0 in forum Fox-SN95
    Last Post: 10-08-2009, 05:04 PM
