Which boost controller do you use, and which would you avoid? Up to now I have had an internal wastegate that I adjusted with a turnbuckle. Now I have the GT2871r with a 38mm Tial external wastegate and need manual adjustment.
Should I go manual or electronic? Let's assume cost is not a concern, but I obviously don't want to spend more than necessary.
I have the tools and skill to make one myself, but I mainly don't want to play guessing games and spend 20 hours finding the right tension spring, dialing in the boost, etc.
I was looking at this: TurboSmart Dual Stage Mechanical Boost Controller
I don't daily drive this car, and I won't be adjusting the boost frequently after I set it. I will adjust to to around 10-12psi for now, and then as high as 20-25psi after I build the spare motor.
My thought with the dual stage is I could run 12-15psi around town and have a setting for 25psi at the track, which I could flip (manually or automatically) after in 2nd gear.
Thanks all
