Just got finished switching my cobra over to a return style system. I'm having trouble getting the fuel pressure dialed in though. When I first turned the key to turn on the pumps they pegged the gauge at over 100 psi. I had to back the regulator waaay off to get it down to 40 psi at idle. Now I find that I'm slowly having to tighten it down to get it back to 40. I set it at 40 then went for a drive and by the time I got home it had slowly fallen to around 30 or so. So I bumped it back up to 40. Now I took the car out again today and after a while the pressure started to creep down a little bit again. So when I got home I took off the vacuum line and put it back up to 40 at idle. So I guess my question is if this is normal? I've never played with a fuel pressure regulator before. My 85 has a mechanical pump and a carb and my old cobra was returnless. My guess is that the pumps and fuel are heating up after driving the car for a while on a hot day then just aren't producing the same pressure as before.
Also the regulator is supposed to be a 1:1 boost to psi ratio which I assume it's supposed to add 1 psi of fuel pressure per psi of boost. This isn't really happening either. The car hits 18-19 psi of boost, but fuel pressure never really rises more than 10 psi or so above base pressure. Anyone ever experienced anything like this before? Is there a solution to this problem?
