Results 1 to 8 of 8
Thread: No turn signals
    Senior Member blackfive-o's Avatar
    Leetsdale
    421
    No turn signals
    92 LX 5.0, turn signals don't work but 4 way flashers do! Changed the fuse and both flashers (all checked out OK). Still don't work. I also have a Painless Performance switch panel in the ashtray that also quit working at the same time, switched for line lock and back up lights. Any ideas for my next move?
    PS everything worked when I bought the car
    Thanks in advance
    "Old Man"
    Trace back the fuse for the painless switch...
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    I'd try your turn signal switch, aka multiswitch. They are known to go bad. They can cause several things to not work, turn signals, headlights, wipers...
    LowHill
    2,679
    Quote Originally Posted by juice_man_86 View Post
    agreed. Mine had a bad connection- no turn signals and no heater blower.
    Jul 2010
    North Huntingdon, PA
    438
    I have an '87 and have lost turn signals twice - both times still had 4 way flashers. First time ended up being relay which it sounds like you've already eliminated. Second time was when I had pulled my dash and had pulled switch to get the dash out. A wire that plugs into the harness had come out and I put it back in the wrong slot ( one over from correct slot ) and it was not making contact. Not sure where you are from, but I have a back-up turn signal lever that I know is good if you want a good one to try out to see if your lever might be the problem.
    Leetsdale
    421
    Thanks for the feedback, I will be tearing shit apart tracing wires. Does the Painless have it's own in line fuse? Do the turn signals and 4 ways utilize the same bulbs?
    "Old Man"
    Leetsdale
    421
    OK, I found the problem! When the car is running, if I turn back on the key just a hair, everything works. How do you change the ignition switch?
    "Old Man"
    1,164
    yep needs an ignition.switch. very common item to go bad in foxes.
    they are around $15 for a new one.
  1. No turn signals - any suggestions ?
    By roush08 in forum Fox-SN95
    Last Post: 08-02-2011, 05:11 PM
  2. oh yay no turn signals, 4 ways, brake lights or fuel gauge
    By bittersweetfox in forum General Tech
    Last Post: 04-21-2010, 09:31 PM
  3. turn key and car wont turn over
    By to50 in forum Ford Vehicles
    Last Post: 11-01-2008, 11:27 AM
  4. sequential turn signals
    Last Post: 05-10-2008, 10:41 PM
  5. 05-06 sequetial turn signals
    By SUPERDUTY in forum Ford Vehicles
    Last Post: 05-10-2008, 08:39 AM
