Results 1 to 10 of 10
Thread: clutch kit / flywheel choices
    Aug 2010
    connellsville
    160
    Hey everyone im going to be doing a t5 swap to my 91 here in the fall my question is with all the flywheel and clutch kit choices out there what would be best for me. By no means is my car a "race car " and I really don't consider it a daily driver since I only drive it less then 50 miles a week Its basically stock. Bored 030 over under drives, a/c and smog delete, hooker super comp equal lengths, off road x 3in, flowmasters comp cams upgraded valve springs and cam. So im not really pushing a lot of horses im just trying to get some opinions on what to go with. Thanks
    Member silvernotch's Avatar
    Bethel Park
    664
    Anderson Ford has a kit thats like the fms king cobra one I have one in my car works fine.
    Aug 2010
    connellsville
    160
    What about flywheels and u know I probably sound like an idiot but what's the difference between 0oz 28oz and 50oz weight how do I know what one to use im new to the 5 speed stuff.
    RRT juice_man_86's Avatar
    Uniontown, PA
    533
    Foxbody Mustangs should use a 50 oz imbalance...unless the motor has been changed...most strokers either use a 28 oz or zero imbalalance.
    Early 289s & 302s ( from the '60s and '70s ) had a 28oz imbalance. The '85-'95 5.0 Mustangs were a 50oz imbalance. I'm not sure exactly what year between '74 & '84 the change was made. Anyway, you need to have a flywheel and a harmonic balancer with the correct / same imbalance as the motor.
    Aug 2010
    connellsville
    160
    My car still has its original balancer from what im guessing I had a shop rebuild the engine last year. Is there anyway to tell what weighted balancer is on the car already.
    The flexplate on the AOD will most likely be the stock 50oz unit, so I'd think you'd need a stock 50oz flywheel. Someone here on SCS should have one lying around.
    Aug 2010
    connellsville
    160
    I have a flywheel on the donor car but I wanna upgraded one
    i picked up a fidanza flywheel it comes with all the weights you would need
    Aug 2010
    connellsville
    160
    I was looking at the ford racing cast replacement flywheel 50oz and the clutch kit silvernotch mentioned above I read the about this flywheel and it says works best with a ford racing clutch kit I would think it would work good also with that king cobra type kit
  1. McLeod St.Twin Clutch/Steel Flywheel
    Last Post: 10-28-2013, 09:40 AM
  2. 11" Spec 2 Clutch w/Flywheel
    By 2000GT in forum Ford Vehicles
    Last Post: 07-20-2012, 10:00 PM
  3. spec clutch and alum flywheel (new)
    Last Post: 05-23-2011, 10:53 PM
  4. FS: '03 Cobra flywheel and clutch disc
    By ModularMike in forum Ford Vehicles
    Last Post: 07-21-2010, 12:28 PM
  5. Clutch/flywheel question:
    By ModularMike in forum General Tech
    Last Post: 05-26-2010, 07:14 AM
