Results 1 to 10 of 10
Thread: Ooops... dropped a socket in my new motor.
    Cheap SOB
    Baltimore, Maryland 21236
    288
    No joke. I went to prime the oil system by running the oil pump off a drill, 24 inch 1/4 drive ratchet extension and a 1/4 socket. Then I realized there was no oil in the engine yet (it was late) so as I removed the extension from the distributor hole. I heard the socket hit clink and hit thin metal. I did not see it happen. The socket is not in the intake. I cannot find it on the front brackets. It is not on the floor.
    I lifted the motor off the mounts a couple of inches and pulled the bolts out of the oil pan. Now the pan is loose and I have almost an inch clearance. When I shake the pan I cannot hear the socket bounce around.
    So, can the socket be in the timing chain area? Where else can it be hiding?
    it is a Ford 302 block.
    Squiggles.......... Erics89GT's Avatar
    Aug 2010
    Greensburg, Pa
    390
    most likely in the timing chain area, hence the distributer and cam gear is in there....i dont think it will mae it to the pan....good luck with getting the socket out
    Daily: 2007 Ford Fusion SE
    1991 LX 5.0 5speed- lowered, mach1 wheels, trickflow intake, boss inc style pro cowl hood, 3.73s
    Cheap SOB
    288
    Pulling the timing chain cover is easier then pulling the motor out to check the pan and etc.
    Huntingdon PA
    1,136
    Pull the timing cover. Use a long magnet if needed to fish it out. I feel your pain. I got interrupted one day and came back and pulled my cam out without removing my lifters. Lost 6 of them in the pan lol. We all do dumb things sometimes lol.
    Sent from my Samsung Galaxy SIII
    709RWHP/750RWTQ
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    Ha. Basically did the same thing. Pulled timing cover and used a magnet.
    Good luck.
    2015 GTPP
    Jun 2007
    2,108
    Eh **** it fire that bitch up.
    Dang that sucks - I've heard of people wrapping duct tape around the whole extension / socket assembly to keep that from happening.
    Senior Member stevec5ws6's Avatar
    Feb 2011
    289
    That sucks man best of luck.
    Cheap SOB
    288
    I bought an engine support bar and lifted the engine as far as the bar would go. When we got under the engine there was a good 4 to 6 inches between the block and oil pan. While I turned to get a flexible magnet, my son just stuck his hand in the front sump and scooped up the socket.
    Ended up not being to bad of a job.
    The engine is buttoned up. All I have left is to charge the battery, adjust the clutch and put fluids in the engine.
    Life is good. :)
    Castle Shannon
    1,276
    dejavu.. after that i got one of these and "disabled" the lock mech.. ;)
  1. MAC tools Lock - A - Socket tray
    By roush08 in forum For Sale
    Last Post: 01-19-2012, 03:48 AM
  2. Replies: 0
    Last Post: 01-07-2009, 11:08 AM
  3. dropped the vert
    By 9002stang in forum Pictures & Videos
    Last Post: 10-18-2007, 05:37 PM
  4. Dropped the GT Off
    By coralcoupe1993 in forum Wolfpack Speed
    Last Post: 09-16-2007, 10:53 PM
  5. Just dropped my car off at Timmy's shop
    By 95riosnake in forum The Bar
    Last Post: 05-27-2007, 10:27 AM
