Results 1 to 19 of 19
Thread: Vortech input shaft problem
    Sep 2007
    Homestead
    780
    I had the bolt break that holds the pulley on. After trying to get it out with an ez out, I'm left with messed up threads.
    Anyone think it's possible for a machine shop to redrill and tap the hole ? It would have to be done with the head unit still together. If I take the input shaft out I may as well just buy a new one.
    Jun 2008
    Bell Acres
    469
    Quote Originally Posted by frankstang View Post
    It's definitely possible. Just realize that you will have to increase the size of the hole, more than likely, another sixteenth inch or another mil or two depending on what kind of threads are there. Then when you have a clean sleeve, it needs tapped. This may require boring out the pulley to work with the increased bolt size.
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    hardest part is gonna be keeping the unit level and square with the drillpress.. Nothing really good to hold onto.
    2015 GTPP
    Is the remnants of the bolt out and just the threads damaged?
    If that's the case, it sounds like a good place for a helicoil. Basically the hole will be drilled a little bigger, re tapped to a slightly bigger size ( specific to the helicoil) then the insert is installed. In the end you end up with new threads the same size.
    Sep 2007
    Homestead
    780
    I'm not sure if all the bolt material is out or not. I think some of it may be packed into the bottom of the hole.
    Does anyone know of any machine shops in the Pittsburgh area that I could talk to about this ?
    I thought about a helicoil, but I'm thinking it may spin inside the hole.
    BTW, the pulley hole is much bigger than the bolt hole, so there will be no need to modify the pulley.
    The pulley slides onto the shaft, then a thick washer covers the hole in the pulley, and a bolt goes through the washer and into the input shaft.
    This is a pic from 928 motorsports
    http://www.928motorsports.com/parts/...eals/VHSS2.jpg
    Jun 2008
    Bell Acres
    469
    I work at a large machining/fab company. Send me a pic. I may be able to have a machinist do it for nearly free.
    Hall Industries. "The Problem Solvers"
    I live in Sewickley and go to work in Ellwood City. Hall used to be in Southside before they grew too large for their facility.
    I don't think you will find a machinist to attempt it. Like mentioned earlier, there tea lly is no way to properly fixture it without disassembly. Especially for a shaft that is made to rotate in the head unit. It needs to be rock solid to be one properly.
    Jun 2008
    Bell Acres
    469
    But you may find a Mustang enthusiast like myself that has access to every tool known to man.
    Something spinning at tens of thousands of RPM, just do it right and leave the cultural engineering to the import crowd.
    Nov 2008
    ELIZABETH TWP.
    885
    Frank go see jake savani in mckeesport and see if he can do anything with it... machinist/engine builder... he is up behind mckeesport high school behind viking lounge at top of hill...
    COREY...
    *04 Torch Red Cobra
    471hp/489tq
    Sep 2007
    Homestead
    780
    I'll get a pic up in a while, my camera is charging at the moment.
    Ed, I know what you're saying. It's going to be tough to hold the whole thing still.
    I'd really hate to have to rebuild it if it doesn't need it though. Is it even worth spending $300-$400 to rebuild an A trim ?
    Probably better off putting that money toward a used S trim.
    Sep 2007
    Homestead
    780
    Here's some pics:
    Personally, I would gothe route of a S Trim head unit since they can be found so cheaply now. I picked up a S trim complete kit for $900.
    Plus that shaft will hardened which may make any new threads you have cut be more brittle.
    Sep 2007
    Homestead
    780
    I'll probably end up doing that.
    I'll hold onto this one and buy a new shaft and rebuild kit one day just because I want to do it. That way I'll have a spare if I ever need it.
    you could send it in and have it upgraded to an s-trim ,i would call vortech for a quote
    As long as the ez out is not buried in there bring it out and I can get the rest of the bolt out.
    Member silvernotch's Avatar
    Bethel Park
    664
    happened to my kids car too. he had a 10 rib set up and it also f ed up the key way slot get a new shaft or an s trim
    Sep 2007
    Homestead
    780
    This sucks because the rest of the blower is in great shape. This is an older unit and there was zero grit or material on the two plug magnets, the gears look great, and the bearings spin freely and quietly.
    Sep 2007
    Homestead
    780
    Ended up buying an S trim head unit. Not sure what I'm going to do with the A trim.
  1. Lentech Strip Terminator input shaft/drum
    Last Post: 05-18-2011, 11:47 AM
  2. Input shaft question
    By yellowstang03 in forum General Tech
    Last Post: 09-21-2010, 06:36 PM
  3. Hours of labor to install a input shaft?
    By speedracer in forum SN95-New Edge
    Last Post: 10-28-2009, 04:27 PM
  4. Replies: 7
    Last Post: 12-08-2008, 10:11 PM
  5. C4 hardened input shaft breakage pix
    By mikeymustang in forum Pictures & Videos
    Last Post: 07-18-2007, 08:48 PM
