Results 1 to 7 of 7
Thread: Best way to recirculate my wastegate??
    Huntingdon PA
    1,136
    Question Best way to recirculate my wastegate??
    Hi guys. I'm looking to recirculate my wastegate on my car. I'm trying to figure out the best way to do this. I have a 44mm Tial gate, and I have a stainless steel flanges that are for my gate. I was planning on buying a flexible piece of exhaust pipe and welding flanges on both ends and connecting it to my down pipe. Problem is that my down pipe is mild steel, not stainless. is that something that I can weld together, and will it be okay under heat conditions? I want to be able to remove this and cap both ends should i desire to switch back and forth. I'm just looking for some ideas. I have an HP Performance turbo setup. I can take some pictures tomorrow for visuals. Thanks for the help.
    709RWHP/750RWTQ
    Jun 2007
    2,108
    Why would one do such a thing?!
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    Yes you can do that.
    Here is my build thread: http://www.steelcitystangs.com/forum...ad.php?t=26379
    The Focus only has half of your cylinders, so just imaging you're seeing double. :D
    All my stuff is mild steel it doesn't crack like stainless.
    Huntingdon PA
    1,136
    Thanks sporadic. I wish those flanges and v bands weren't so expensive! this is going to be costly. I've been wanting the option to add and remove open wastegate.
    709RWHP/750RWTQ
    Fairmont, WV
    2,467
    Quote Originally Posted by billyNOTnice View Post
    At least you can use 2" v-bands for your wastegate. The 1.5" v-band is nearly impossible to find so I had to use those flat flanges. I'm loving the 3" v-band on the rest of the exhaust though!
    Huntingdon PA
    1,136
    :) I'm hoping i'm going to love mine. the problem with v-banding everywhere is that where my down pip is I almost need it on a band clamp so i can move it around. If i v band it, then i'll never be able to make it longer or shorter if i change my setup.
    709RWHP/750RWTQ
  1. wastegate
    By pwtmxracing in forum Ford Parts
    Last Post: 03-27-2011, 07:54 PM
  2. Wastegate
    Last Post: 12-01-2009, 04:24 PM
  3. Internal Wastegate
    Last Post: 06-29-2009, 06:22 PM
  4. turbonetics 38mm wastegate
    By blaze00 in forum Ford Vehicles
    Last Post: 06-03-2009, 02:16 AM
  5. DIY: Adjustable wastegate actuator
    By sutyak in forum General Tech
    Last Post: 02-04-2008, 01:09 AM
