Hey guys, I just dropped the new 347 stroker (new as in rebuilt) in the fox last weekend. Broke it in, everything went fine, have been driving it quite a bit before I take it to Street Lethal for a tune (trying to get 500 miles). Everything has been going great so far, except for yesterday, I took it on a 2.5 hr drive, stopping halfway for lunch.... everything went fine on the trip as well (most of the drive was not on the highway, and when i was i never really stayed same RPM's) well when I was going to leave and come home yesterday, I was not getting good oil pressure on the gauge. When I would rev the motor, it would get around 16lbs, at idle it barely has anything. I changed the filter thinking it was just junked up from bits of stuff from initial break in. That did nothing.... I tried to prime the system again... I can get the gauge to read about 20lbs. I took the gauge off and blew air through it to see if it was messed up and it read 40lbs, so the gauge is fine. I dont know what else to try... could this be the oil pump? (and yes for you smart asses out there I did check the oil level lol) Before this issue, I could start it and it would have 60lbs cold, then 40lbs hot. The motor makes excessive noise when i start it, but nothing banging or clanking... moreso just sounds like stuff isnt getting enough oil. I put good oil in it for break in and it looks brand new still... I put in shaeffers oil. SO I know the oil isnt junk @$50 something a case... lol. Any thoughts or suggestions? This sucks!
