Results 1 to 18 of 18
Thread: First time ever to PRP
    Member AdaBonGT's Avatar
    Mar 2012
    Pittsburgh
    34
    Finally got a chance to get out to PRP for a few runs. My best time with big traction issues on my street tires and a 60ft over 2 secs was a 13.3 @ 108mph.
    What should I be trapping at with that trap speed? Trap should be higher too but I couldn't hook up.
    I know I could do better with better tires or even just a new tune to take full advantage of my built tranny w higher stall.
    98 GT conv. PI intake, MHS stage III ported PI heads/Stage 3R Bullet Cams, CAI, BBK 78mm TB, LT headers, Mac o/r prochamber, SLP LM1, FRPP pullies, FRPP 4.10's.
    That 60ft time is killing you!
    2011 Mustang GT Kona blue
    2002 F-150 FX4 true blue, with Lightning blower swap
    2004 F-150 FX4 forged bottom end, built trans, Street Lethal Performance 76mm turbo kit, Black, Gray Leather, 6"susp, 3"body on 37's
    Let us know your parts needs we will work to beat any price!
    (724)964-8419
    9am-5pm M-F
    In house chassis dyno
    Mar 2012
    Pittsburgh
    34
    Yeah tell me about it lol. Spun through first and beginning of 2nd. I'm pretty sure my converter is locking up way too soon. Even going from park into drive or reverse with my foot pretty heavy on the brake the tires will spin.
    Member travj31's Avatar
    Uniontown
    1,688
    108mph should put you well into the 12's... i'm thinking like 1270's-1280's give or take
    Mar 2012
    Pittsburgh
    34
    That's what I was thinking. My trap was faster than the guy next to me and he was running 12.8's with a 60ft just under 2 secs
    Polar Vortex
    6,031
    What is it, every 1 tenth off the 60 nets two tenths off the ET?? If I remember right.
    Based on a basic Wallace calculator ...
    60 Foot1.71
    330 Foot4.93
    660 Foot7.74
    660 MPH87.80
    1000 Foot10.18
    1/4 Mile ET12.27
    1/4 Mile MPH108
    Link to calculator:
    http://www.wallaceracing.com/etcalc.php
    That is usually okay for estimating. What happens however with spinning is that you can trick the MPH up a bit, so when the 60' comes down, so does the MPH.
    A better estimate can be made if you have dyno numbers, MPH,and weight ;)
    it's soo-tack sutyak's Avatar
    Fairmont, WV
    2,467
    MPH definitely drops when the 60' drops. In my Mach 1 I dropped a full 1mph going from a 2.0 60' to a 1.74 60', but ET went from 13.1 to 12.61.
    What is your launch technique - what rpm are you leaving at? What tires are you running, at what psi, and how do you do your burnout? What was the 60' times? "Over 2 seconds" = 2.01 to 2.99 to me.
    ChuckT
    Sponsored by
    Millerstown Pic A Part
    Jun 2007
    2,108
    Did you say your torque converter is locking during the run? I would avoid locking the converter especially on an N/A car.
    Mar 2012
    Pittsburgh
    34
    60ft was a 2.06. Running nitto 555's at about 25lbs. Nothing crazy on burn out since just on streets. As for launching had foot hard on the brake and rpm around 1k, at last yellow light release brake and hammer it. Anything over 1k I would start to spin the tire.
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    2.06 isn't great but not exactly terrible on junk street tires. In real life it is actually pretty decent for your stock rear suspension. Get real rubber and go back, instant 1.7-1.8 60s and mid to high 12s with your mph, then fix your converter issues if you in fact have any.
    2014 M235i (wife's)
    1964 Ford F-100
    Mar 2012
    Pittsburgh
    34
    Rear suspension isn't stock. I have J&M rear lower control arms, bilstien HD shocks, and ford racing C-springs. Rear end has 31 spline ford racing trac-lok w/carbon fiber discs (essentially a cobra rearend) and moser 31 forged axles.
    Trafford, Pa
    2,308
    Quote Originally Posted by AdaBonGT View Post
    Stock suspension as in "stock four link".
    2014 M235i (wife's)
    1964 Ford F-100
    Mars, PA
    1,696
    I don't see a converter listed in with your mods. A higher stalling converter along with sticky tires would do you wonders. Based on previous experience I doubt tires will help you much on the stock converter and you might see 1.9's at best
    Dennis
    2006 GTO
    Gone but not forgotten
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    Mar 2012
    Pittsburgh
    34
    Its a 3000 stall but like I said before its locking up waaaaay too early. I have a new tune for my tranny and it feels so much better and I can actually tell I have a higher stall but it has idle issues and can't run it, stalls out when car idles down.
    Mars, PA
    1,696
    Very odd, the only time it should lock is normal driving in 4th. Perhaps its not locking your experiencing but just the limits on where it will foot brake before pushing through.
    Dennis
    2006 GTO
    2015 SHO
    Mostly stock
    2014 Cruze
    Living the MPG life
    Mar 2012
    Pittsburgh
    34
    With the tune I'm using now it will spin the tires just shifting from park to drive or reverse and also is causing some bucking when cruising because its locking and unlocking too early (straight from the guy who built my tranny, he's worked/works with Evanuik on race cars so I trust him). The new tune that I can't run doesn't do this and rpms react completely different while driving, can notice the stall clear as day with the new tune.
  1. Well, it's about that time again!
    By Scott Rod Fab in forum Scott Rod Fabrications
    Last Post: 10-03-2011, 09:45 PM
  2. New best time at PRP last night (9/8/11)
    By Seer in forum Drag Racing
    Last Post: 09-10-2011, 02:44 PM
  3. Its about time!!!
    By street591 in forum The Bar
    Last Post: 10-14-2009, 01:24 PM
  4. Replies: 7
    Last Post: 09-02-2008, 11:28 PM
  5. PRP start time change for this weekend
    By CobraII in forum Drag Racing
    Last Post: 08-05-2008, 09:21 PM
