Results 1 to 5 of 5
Thread: 93 Cobra motor vs. 94/95 Cobra motor ?
    5,822
    Lightbulb 93 Cobra motor vs. 94/95 Cobra motor ?
    I searched our site, but I was too lazy to search da hole innanet.
    I know somebody on here knows if there is any difference in the engines (other than the bent upper intake because of the sn-95 strut tower).
    Internally speaking, same heads, cam, pistons etc?
    The '93 Cobra is highly desirable for obvious reasons and priced accordingly, but I've seen a few 94/95 Cobras that are fairly reasonable.
    Thanks for the info.
    edit: found the link I was looking for, but it doesn't get real in depth...http://www.svt.ford.com/svtArchiveCobra.asp
    shaler,pa
    1,010
    i believe that the only difference was the camshaft
    Member 97 Mustang's Avatar
    Gibsonia, PA
    113
    Big member venom's Avatar
    North Fayette Township, PA
    1,344
    I think the 93 was rated at 235hp, and 94/95 were 240. That cam change might be where that 5 hp comes from.
    2015 GTPP
    Careful, it bites... 93Cobra5.0's Avatar
    Atlantic, PA
    85
    you are correct, however both motors were highly underrated from the factory (true output was somewhere in the 265hp range) Also the 94-95's had a raised lettered intake cobra logo while the 93's had a adhesive plaque that attached to it.
    Almost forgot, also the 93's had stamped steel black valve covers (plain)while the 94/95 counterparts had "cobra" lettered valve covers
    - mike
    - 93 Mustang Cobra
    (bolt ons) sold :(
    - 04 SVT Focus (intake/udp/off road pipe)
    - 89 Probe GT (mbc @15psi, chip, 2.5'' catback)
  1. mach 1 motor vs cobra motor
    By 89stang in forum The Bar
    Last Post: 07-28-2011, 10:45 PM
  2. 03-04 cobra motor model
    By PSPstang in forum Ford Vehicles
    Last Post: 09-12-2010, 10:43 PM
  3. Motor and trans. from 93 Cobra
    Last Post: 04-17-2008, 12:03 AM
  4. Fox with 03 cobra motor
    By molnartr in forum Pictures & Videos
    Last Post: 02-24-2008, 07:50 PM
  5. panoz with cobra motor
    By GOT SVT in forum Ford Vehicles
    Last Post: 08-18-2007, 02:15 AM
