Sold ...
Mostly all stock with AC. Really nice Opal grey interior. No rust to speak of. Only 2 owners since new with 60K miles. Pony wheels with Michelins. Optima battery. It does have 3:73 (?) gears and speedo was never corrected, so actual mileage is lower. Also has older bolt on frame connectors, looks like underdrive pullies and underhood K&N air filter. Runs and drives great. Inspected until 8-13, probably 500 miles give or take since inspection. All VIN tags in place. Original window sticker and manuals go with the car. Newer headlights, I have the originals. Aftermarket radio that it took me forever how to turn it off (and haven't used it since), but I have the original Ford unit.
Emissions exempt. It does have an off road H pipe but I have the original with cats that goes with the car. New front pads and rotors, new rear wheel cylinders. Needs some tidying up: Door lock actuators need replaced, drivers side power window switches work when they want (most of the time they're okay), front bumper cover paint is delaminating, passenger door mirror has turned gray as has some of the other trim. Has some light damage to the right rocker and right lower door. AC was blowing not so cool last time I used it.
EDIT- Ashtray door needs the usual. Left 1/4 panel shows signs of paintwork above the moulding, but I finally got around to wet sanding this panel and don't see the reason. The paint is 20 years old .... Hurst shifter with round lever and black ball, have additional flat lever with white ball.
All in all a NICE adult owned car, but it's out of sight and out of mind at the moment in storage. So I'm tempted today to let it go for $5950 cash semi-firm. A $500 non reundable deposit will hold the car for 2 weeks. You can reach me before 9:30PM any day, any time. Leave message if you get recorder or voice mail and I'll get back to you: four 1 two // 4 eight 6 // nine 1 three five
I will add photos by Saturday ..... Car located in North Hills.
