Results 1 to 10 of 10
Thread: Stock Fox front spring install
    formerly Nsty98LS1
    Jun 2008
    Lilly, PA
    549
    This might be a stupid question, but I'm about out of ideas, so here goes: How in the hell do you reinstall the stock front springs in a fox body? I've tried spring compressors, chains, long bars, etc... & no luck. I'm not really looking to commit suicide to get them either. lol What is the magic trick? Lowering springs are not an option at this time until the car is finished & I see how it sits with the new drivetrain.
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    Never have done it but if I were to try the first thing I would do is remove the bolts that hold the control arms in, and jack up the a-arm with the springs installed until the bolts can be re-installed.
    2014 M235i (wife's)
    1964 Ford F-100
    formerly Nsty98LS1
    Jun 2008
    Lilly, PA
    549
    Me & my friend attempted that & it got real scary! lol
    Your mom cwh19's Avatar
    May 2009
    Greensburg
    1,383
    Do you have access to a lift?
    15gt
    94gt
    Mt Pleasant, PA
    4,905
    I compress them outside the car, strap them with a bunch of mechanics wire on 2 sides, install them and then cut the wire loose. Make sure not to wrap the wire on the upper and lower end of the spring, once the spring seats you would have a hell of a time getting the wire out. Not the safest but if you make about 15 loops on each side and then tie it off, it has always held for me.
    fairmont,WV
    1,352
    Like Lou said, but I used the giant zip ties that the HVAC guys use. Works like a charm.
    XXX RWHP
    XXX RWTQ
    Oct 2010
    300
    Uhm i just held them in place and put a jack under the control arm works for me.
    hmmm what's next?
    formerly Nsty98LS1
    Jun 2008
    Lilly, PA
    549
    Well, I think I have it under control now. I used a ziptie, chain & prybar to locate the spring & pop it into the pocket, then just jacked the control arm up to go into the spindle. I'm pretty cautious around front coil springs as I've seen them go through a block wall in the past, luckily no one got hurt during that incident
    Senior Member Dan B.'s Avatar
    Armagh, PA
    4,331
    I do as Mark said. Takes me about 45 minutes being careful and by myself to do each side.
    Ahh fuque
    1986 Ranger--2WD, 5.0/T5/8.8.
    Sep 2007
    Homestead
    780
    This will save you hours of frustration.
    [ame="http://www.youtube.com/watch?v=stNSSOo8Gjs&list=FLKO_q1r8VGSSZPZY-lKfoOQ&index=12&feature=plpp_video"]79-04 Mustang front spring install with the Maximum Motorsports Tool MMT-8 $14.97 - YouTube[/ame]
    http://www.latemodelrestoration.com/...FY-d4AoduWgAWQ
  1. stock rear coil spring
    By black 94 in forum Ford Parts
    Last Post: 12-16-2014, 01:11 PM
  2. Fox Upper spring mounts
    By Floyd in forum Ford Parts
    Last Post: 08-20-2012, 11:12 PM
  3. Front Drag spring ???
    By lib88stang in forum General Tech
    Last Post: 01-15-2011, 04:55 PM
  4. fox body spring question
    By PSPstang in forum Fox-SN95
    Last Post: 10-31-2007, 06:52 PM
  5. Help With Spring Install
    By da9k1ne in forum General Tech
    Last Post: 10-23-2007, 11:54 PM
