Results 1 to 14 of 14
Thread: Vibration in Drive train
    Ok my vert has a vad vibration in the shifter. I thought the rear end was off because the bushings were bad. I put new upper and lower control arms. Vibration is still there. It is bad at high speeds and or rpms. Its not the damper pully. At 80 its real bad, even when I pull it out of gear and shut the motor off. Any more sugestions?
    out in the woods
    4,948
    driveshaft? harmonic balancer? flywheel? check the driveshaft bolts, they come loose
    Pittsburgh, Pa
    459
    if you still get it at high speed, in neutral, with the motor shut off. Means it is either back half of trans or further back. driveshaft, diff, or axles. I would first check driveshaft bolts, and give the front yoke a push up and down to see if there is any play in the output shaft of the trans while your under there. did you have the driveshaft off recently and not reallign the pinion flange to the yoke??
    Farmington WV
    4,672
    check DS bolts and tires still.
    State College, PA
    3,552
    is it only when you let off the gas? because my vert does that at higher speeds when you let off the gas it vibrates like mad but i dont know wat it is
    2013 Mustang GT
    1999 Contour SVT
    Farmington WV
    4,672
    my old 95 did that when the gears werent aligned properly...something about the backlash being off.
    I already changed the drive shaft thinking that was the issue.
    Its when I am on the gas too.
    State College, PA
    3,552
    hmm i dont know what it could be cause it feels like its right under the shifter just like coral's
    2013 Mustang GT
    1999 Contour SVT
    State College, PA
    3,552
    oo thats different...for mine it goes away if you give it gas
    2013 Mustang GT
    1999 Contour SVT
    Mine goes away above 5800 RPM
    Pittsburgh, Pa
    459
    how's your trans mount? just a thought but if it is starting to crack,or sag, like all the stock rubber ones do, might be part of the problem. and when you swapped driveshafts, was there any output shaft endplay in the trans?? alittle is ok, but not much.
    Member itow's Avatar
    Warfordsburg/Breezewood, PA
    107
    I still think it is an alignment angle issue with your rear end. Many things can cause it, torque boxes or control arm mounting points pulled/shifted from stock, control arms not the correct length (one or more), anything bent, bad mount (trans or engine if they are really bad).
    If it does it in neutral with the engine off, that eliminates the engine totally (along with the balancer and flywheel/clutch assay's). It is transmission rearward where your problem lies for sure..
  1. Replies: 14
    Last Post: 12-24-2011, 12:04 AM
  2. New Pipes On the Night Train
    By Rio94gt in forum Pictures & Videos
    Last Post: 09-09-2009, 11:12 PM
  3. HD Night Train (Updated Photos)
    Last Post: 07-21-2009, 01:40 PM
  4. My 2004 Harley Night Train
    Last Post: 07-06-2009, 10:09 PM
  5. Night Train
    By Mater in forum The Bar
    Last Post: 08-21-2006, 03:33 PM
