Results 1 to 6 of 6
Thread: Wheel/tires combo for Terminator with factory coil springs?
    Gibsonia, PA
    323
    I am planning to return my vert to factory ride height by putting on a set of stock coupe springs that I got.
    Does anyone know of a proven wheel size and tire size combo that would fill up the wheel wells better than the factory wheels?
    I am not opposed to different sizes on the front and back.
    Tired of worrying about the roads in Pittsburgh and just want to drive the car without hitting the bottom.
    Gibsonia, PA
    323
    Nobody has ever tried to keep their Cobra on stock suspension and just change the wheels?
    Brookline
    2,897
    18x9" with a 285/35/18?
    Gibsonia, PA
    323
    Thanks. I will look into that.
    Brookline
    2,897
    Quote Originally Posted by 95DropTop View Post
    That is similar to what the 2000R had, except they are 18x9.5"
    Or you can do a 18x9 with a 275/35-18 up front and a 18x10 with a 315/30-18 out back. Thats probably one of the more common combos.
    4,321
    OEM springs with no isolators front or back has a decent stance over stock...
  1. Terminator factory cat back
    By Rej082 in forum Ford Vehicles
    Last Post: 09-04-2014, 04:52 PM
  2. wheel/tire combo
    By 92 stang in forum The Bar
    Last Post: 04-09-2013, 11:15 AM
  3. tire/wheel combo
    By 92 stang in forum Fox-SN95
    Last Post: 04-03-2013, 03:39 PM
  4. Wheel/Tire Combo
    By 40thGT in forum SN95-New Edge
    Last Post: 03-04-2012, 02:04 PM
  5. Tire/wheel combo?
    Last Post: 04-28-2008, 07:23 PM
