Team z stuff are nice parts that should take 30 lbs off or so
V8 bell adapter bolted up ...
SFI V8 bellhousing bolted up ... Now I need to find my dial indicator
Can't see the engine for the bellhousing ... 2.3 liter block hiding behind a 5 liter bell :D
I'm not sure if any of you have ever indexed a bell housing ... This is the first one I've done outside the car so you can see the set-up.
Dial indicator on a mag base. Mag base is on the flywheel, and the bellhousing is bolted up. Set up the dial indicator on ZERO at the bottom ...
Rotated the crank shaft 180 degrees and get a reading ...
In this case it is .030 difference top to bottom and dead on side to side. For what it's worth, I also reset the dial indicator to ZERO on the top and spin it over to the bottom to endure it's the same reading and not something in my set-up.
You take 1/2 the total reading (.015) and order the closest offset dowels made (available .007, .014, .021). So in my case I need ot order the .014 offset pins, and that should put me within the .005 allowable error (should be .001 or better).
I always do mine, but this was the first time I had it out where I could get pictures.
where is the nozzle fitting on the bell?
To be determined once I bolt the actual clutch and pressure plate up. Likely wont be needed with this new set-up, but i'll put the port in just in case ;)
It's a good news / bad news deal ... With the dowels and countersunk bolts on the 2.3 side there is no play in the system ... On the V8 side the dowels are pretty much a light press fit, so no play. The offset dowels will get me where I need to be.
Nice work Bob
G Force is out of the car and torn down for freshening. All the gears and bearings looked perfect.
The root of ripping into the transmission was an intermittent issue with it power shifting into third. I think Rob found my issue.
That's my shift selector finger ( top) versus a replacement (bottom)
can it be straightened?
could you do a hardness check on it and maybe heat treat the new one so this doesnt happen again ?
New spring package for the waste gate ... Finally got to use the big blue spring
