Results 1 to 8 of 8
Thread: 86 Mustang GT, TKO 500 (no engine) drag car
    Uniontown, PA
    135
    1986 Ford Mustang GT - Drag setup but still street legal and driven
    Ran 10.3 @ 139 (with 408 engine and vortech supercharger)
    No Engine (sold engine and supercharger 3 years ago)
    Clear title (owned car since 98')
    Car featured in Modified Mustangs Magazine.
    All items below professionally installed and taken care of.
    Selling due to changing priorities and lack of funds, I can’t see storing the car in my garage if I will not be able to put a new engine in it in the near future.
    Custom checkered Blue and pearl paint job
    TKO 500 transmission - 26 spline input (purchased new, and has very low miles)
    bellhousing setup for 351W
    RAM HD Powergrip clutch
    351 pressure plate (SFI approved)
    351 Damper (SFI approved)
    Aluminum driveshaft (mated output shaft for TKO 500)
    Aluminum clutch quadrant - fast release
    Steeda Adjustable clutch cable
    AEM standalone computer for Mustang - fully programmed and setup for Speed Density w/GM MAP sensor (model 30-1400 EMS)
    GM LQ9 wasted Spark ignition system (8 coil on plugs)
    high volume intake pump(Walbro GSS340 HiPressure 255LPH Fuel Pump) , inline high volume pump, 1/2" braided fuel lines, 5/8 fuel rails, Areomotive FPR
    solid motor mounts
    polyurethane Transmission mount
    polyurethane cross member mounts
    polyurethane power steering mounts (offset)
    ASP 7" Overdrive 8 rib one-piece crank pulley w/4" underdrive accessories and 3.33" SC pulley
    Vortech high volume Aluminum Discharge Tube with Mondo bypass
    K&N 9" Air Filter
    Morpheus 4" Power Pipe
    Trick Flow Tall Valve Covers
    1.6 Stud Mount 7/16" Roller Rockers by Summit Racing (15 of them, one is broken)
    75mm Throttle body and 75mm EGR plate
    FMS Aluminum Driveshaft
    FMS Mini-Starter (high torque)
    UPR Smog Pump Eliminator Pulley
    93 Cobra Overdrive WaterPump Pulley
    ASP/FORD Underdrive power steering pump pulley
    3G 130AMP alternator
    AutoMeter 5" Monster Tach with shift light
    Autometer 2 5/8 Water temp
    Autometer 2 5/8 Oil Pressure
    Autometer 2 5/8 Volt
    Digital boost gage with memory
    2 1/8 Fuel pressure gage
    2 1/8 Vac/Boost
    1 3/4" Full length 351W long tube headers with 3" ball and socket collectors
    Custom 3" exhaust
    3" 1 chamber Flowmaster mufflers with dumps
    Wide Band O2 sensor - setup with AEM
    5 bolt axles/drums
    5 bolt 11" slotted rotors with green stuff pads
    UPR chromoly K-member, A-arms, coilovers w/ 14"-130 springs
    UPR bumpsteer kit
    UPR chromoly solid upper and lower controls arms
    UPR rear anti-rollbar
    upper and lower battle boxes (welded)
    Steeda full length sub-frame connectors (fully welded)
    Weld draglite rims (front 15x6 - 225/50/15, rear 15x8 - 265/50/15 tires)
    Mickey Thompson ET Street 26X11.5X15 Tires
    Draglite 15X10 drag rims.
    Strange 10 way adjustable shocks and struts
    Global West Caster/Camber Plates
    S&W 8 Point Roll Cage
    RJS 5 Point Seat Belts (2)
    Taylor Aluminum Battery Box mounted in the hatch – above RR tire (with battery)
    Taylor 150AMP cutoff switch
    Completely built 8.8 rear end
    3.73 gears
    Strange bullet end caps
    aluminum diff cover
    welded axle tubes
    33 spline Moser axles
    5/8 studs
    9" bearings (welded on) [c clip eliminators]
    lightweight spool
    (rear built to handle over 800HP)
    140 MPH speedometer
    Autometer Electric Fuel Pressure Gauge
    Autometer Boost Gauge
    A-Pillar dual Gauge Pod
    Harwood Pin-on 2.5" Cowl Induction Hood
    Aluminum front and rear bumpers
    Plastic headlights
    SVO Leather Shift Knob
    7 quart canfield oil pan w/supercharger drain port
    Sony CDX-MP30 mp3 head unit
    Sony Speakers 5 ¼ Front, 6X9 Rear
    Car passed tracked safety down to 10.00 second bracket.
    I am selling all parts and items related to this hobby. I have many bins of related parts and previously removed, such as:
    wiper motor, seat belts, springs, etc
    Odometer reads around 130k, All modifications done in the last 30k
    Car was parked 3 years ago after the 408 engine blew a piston. I then sold the engine and supercharger with plans on a bigger engine and blower. Car has been stored since.
    Body is in fair shape. No dents, but several cracks, chips and scratches from years of burnouts and trailering.
    Package deal for all
    $6000 OBO
    The only items I am willing to separate:
    AEM 14-1300 Standalone Engine Management computer $1000
    TKO 500 Transmission and shifter $2000
    2 rear Weld Drag Lite 15X10 rims and MT ET Street 26 X 11.5 X 15 Tires $600
    Also have a 15’ open deck Econo trailer. Purchased new in 2006. Used very little to tow this car. Tires are perfect, always covered. LED lights, brakes work perfect.
    http://www.econotrailer.com (model ET154B-102)
    Will sell trailer and car for $7500 (will help you load it).
    Trailer alone for $2200
    Cash or Paypal(I will pay Paypal fees)
    Title transfer upon cash or validation of transaction
    Location Uniontown PA 15401
    724-984-6905
    1986 Mustang GT, 408, Vortech Si-Trim, TFS 205CNC, 373s, TKO500, AEM, 10.3@139
    Kittanning/Butler
    1,055
    Good looking 4 eye! blws!
    Uniontown, PA
    135
    Sold
    Congrats on the sale. Definitely a pretty 4-eye!
    Did you sell the whole package together?
    Uniontown, PA
    135
    Sold everything except for the trailer as one package.
    15' open deck trailer still for sale: $2200 OBO.
    Thanks.
    Jun 2010
    volant, pa 1 hour 10 minutes to summit
    576
    congrats man. i cant even give free stuff away on here
    6.4 litre fox and its all ford
    You might have some bites on the trailer if you post a new ad with photos and details. Whoops - just saw you have a link in your original post. Sorry 'bout that.
    Jun 2007
    2,108
    Might sell trailer if you weren't asking within $150 of what it cost brand new now.
  1. Liberty built TKO 500
    Last Post: 10-12-2013, 01:21 PM
  2. faceplated TKO 500
    Last Post: 10-18-2012, 11:52 PM
  3. tko 500/600 or a 3550
    By 1slow46 in forum Ford Parts
    Last Post: 05-01-2012, 03:59 PM
  4. Tko 500
    Last Post: 11-06-2010, 08:38 PM
  5. TKO 500 or 600
    Last Post: 06-30-2007, 12:09 AM
