I just found ford racing has a new letter cam the g might try it in my coupe
226/228 .498/.510. Yawn. :p
Not much "bigger" then anything else they offer, don't really see the point, looks like an F with less lift and a bit more exhaust duration.
2014 M235i (wife's)
1964 Ford F-100
I bet it's a big improvement over the older grinds
Ford came out with the "FU Cam" when he bought a slo-maro...
I'm not sure what the specs are of the cam in my 351 but I want to go roller I'm pretty sure it has a flat tappet in it now
You finally found the G spot?
I just wish the retro lifters weren't so expensive
I hope your not going to put a cam that small in a 351?
2014 M235i (wife's)
1964 Ford F-100
It says in catalog it's for a 351
2014 M235i (wife's)
1964 Ford F-100
I have heard some guys are testing it with good results
Sesame Street The cam of the day is "G"
with some 1.7 rockers it might not be too bad
