Results 1 to 13 of 13
Thread: Bumpsteer Kits
    formerly Nsty98LS1
    Jun 2008
    Lilly, PA
    549
    Bumpsteer Kits
    I'm looking to purchase a bumpsteer kit for my Fox after installing a AJE K-member. My question is, which style is the better kit, the tapered end that doesn't require drilling the spindle or the style that does require drilling the spindle? The car is 95% street use at this point. What are the pros & cons of each style?
    Somerset Co.
    2,907
    The Steeda kit was the best quality out of all the ones I've seen... I'll go 1/2 on a bumpsteer gauge if you want.
    formerly Nsty98LS1
    Jun 2008
    Lilly, PA
    549
    Greg, that's a good offer on the bumpsteer gauge, however I think I'm going to do a little trial & error until I get as much bumpsteer out of my car as I can for the time being. The way it is right now, I think it would be a real pain to drive & would scrub my tires real quick. If I can swing lowering springs & c/c plates this year I may take you up on the going half offer though.
    Somerset Co.
    2,907
    Quote Originally Posted by JOlbert View Post
    http://www.summitracing.com/parts/ln...0/media/images I need to do my rear... I have the offset rack bushings on mine, you might want to try that first since they are only about $20
    formerly Nsty98LS1
    Jun 2008
    Lilly, PA
    549
    If I put the offset bushings in my rack, it will hit my oil pan. I didn't know anything about AJE moving the rack position down until my steering shaft was about a 1/2-3/4" too short.
    Somerset Co.
    2,907
    Who was the idiot that wanted to put that engine in the car?
    Thats what she said...
    formerly Nsty98LS1
    Jun 2008
    Lilly, PA
    549
    It looks like it should've been in there stock. Well, except the fuel line feeding the rails but that might change if I can find the right factory hose
    Member Mark Aubele's Avatar
    Trafford, Pa
    2,308
    The Steeda kit was the best quality out of all the ones I've seen....
    I'll second this. For a track car (road course/autocross/etc.) I wouldn't run a tapered kit, but for a drag/street car I wouldn't have an issue with it. The reason for drilling the spindle is the added strength of being able to use the same size bolt all the way through (some of the spacer stacks can get thick), and the tapered exist because you don't have to drill the spindle (a 5 minute job).
    2014 M235i (wife's)
    1964 Ford F-100
    Apr 2010
    South Hills
    3,579
    So the Steeda kit wouldn't be ideal for a autocross/road set up?
    -Barry
    Trafford, Pa
    2,308
    I ran it for years without any problems, then I drilled the spindle later and used the same kit, just replaced the tapered part with the same thickness bolt. The bumpsteer kit is one of two things Steeda sells that would go anywhere near my car, surprisingly it is a quality piece.
    2014 M235i (wife's)
    1964 Ford F-100
    Apr 2010
    South Hills
    3,579
    In guessing the other is the x2 ball joints?
    -Barry
    Somerset Co.
    2,907
    I have these CC plates from them and they are well built
    http://www.steeda.com/store/steeda-b...d-mustang.html
    And their billet front swaybar mount
    Apr 2010
    South Hills
    3,579
    ^ drool.....
    -Barry
  1. Clutch Kits, etc.
    By cLockWise in forum SN95-New Edge
    Last Post: 03-03-2013, 09:22 PM
  2. WTB: bumpsteer correction tie rods
    By somethingclever in forum Ford Parts
    Last Post: 03-19-2012, 03:32 PM
  3. Steeda Bumpsteer kit
    Last Post: 06-19-2010, 05:34 PM
  4. Timesert kits
    By Ares in forum General Tech
    Last Post: 12-16-2009, 04:52 PM
  5. body kits?
    Last Post: 08-04-2009, 10:49 AM
