Saw this video on youtube: 5.0 Mustang Coyote Auto Meter Gauge Installation - YouTube (7:02-7:24) but wanted to show how I hooked up the fuel sender on my car vs. the way they did in the video which left the sender, wiring harness & a cut up engine cover in the end. A brass elbow gave enough room to mount the sender and let it completley hide under the engine cover. You can relieve fuel pressure per the Ford repair manual by disconecting the fuel pump connector in the spare tire well in the trunk, start the car let it run till it shuts off, then crank engine for 10 seconds. be sure to key cycle the fuel pump a couple times to prime the system before starting once finished.
