Doing some work Mark!
2015 GTPP
I loved staring right at the guardrail when you were sideways. Awesome!
Decided to try to get some weight out of the AS car. Not much I can do really, we have to keep all the stock glass save the doors and quarters, factory hatch, etc. The doors are open though. Not sure why, but the previous owner had partially gutted the driver's door, and left he passenger alone except for removing the glass and associated motor and whatever else makes it work.
Before...
After...
I had heard the actual door bars weighed anywhere from 12-35 lbs each. They weighed 15.5 a piece, and the skin removed weighed 5. I chose to cut them out rather than drill out the spot welds because I am ****ing lazy.
2014 M235i (wife's)
1964 Ford F-100
Ditched the upper control arm setup I was using. Put my old Steeda double adjustables back in. New Spherical bushing in housing. Replaced both rear springs with Eibach drag springs and added an airbag.
Going to swap out the 150lb springs for 130lb up front. Swap out injectors and MAF. That will get done tomorrow after running out to Summit to grab new set of gears. The 4.10s have got to go. Really, really needs more gear.
put some new oil in the yellow car today i hope to get some more parts on it tommorow too
New front springs on. Actually rides a little better on the street now. Cleaned the air filter. Thing was filthy and runs a little better now.
Got the new gear set. Richmond 4.30 They are not 4.33 as marked on box. Suppose to be 9t pinion/39t ring gear but are 10t pinion/43t ring gear.
O/R X is on.
-Barry
Oh yeah...
-Barry
Barry car sounds great!
Sent from my SCH-I405 using Tapatalk 2
I just got done installing Steeda adjustable upper control arms and correcting the pinion angle. While I was at it, installed an FRPP aluminum driveshaft.
Got mine towed!![]()
What happened now?
-Barry
Battery or alternator. Died at gas station and wouldn't take a charge. Brand new battery so I'm afraid it may be the latter.
